My blue star air conditioner not working display shows H6
Airconditioner
    New Friend:
H6 fault
Posted on May 17, 2014
  • G.manikandan Jun 02, 2017
    H6 fault how to solve
  • 4736 Answers
SOURCE: how do I reset my energy star air
Turn the ON/OFF switch to OFF and unplug the unit for 15 minutes. Then plug the uni back in and turn it ON. During that 15 minute timeout, the unit should have reset itself and reverted back to the original factory settings. If it did, you can set the controls as you desire.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 25, 2011
SOURCE: panasonic cu24 air conditioner
Our unit is returning error H19.
Posted on Jan 07, 2008
SOURCE: Mitisubishi Ducted Reverse Cycle AirConditioner
Smoke coming out of vents and air smells
Posted on Feb 09, 2009
  • 400 Answers
SOURCE: Water level float switch error
You do not mention the model, I presume that it is a cassette, in which case the float switch is located in the indoor unit. You have to remove the cover which is 4 screws. First make sure all power supply is turned off. Then remove the drain pan which surrounds the fan blade. You will see in one corner of the unit a slightly deeper part of the drainpan, this is the corner where both the condensate pump as well as float switch is located. Before you do any of this, give a serious blow into the drain pipe from outside and this may dislodge any sludge which may be causing the floatswitch to stick. You can also pull out a rubber plug which is under the pump on the drainpan.
Posted on Mar 05, 2009
  • 340 Answers
SOURCE: can i reset the remote for my air conditioner? it
they are not resetable. did it get wet? Good luck Tom
Posted on Jun 28, 2009
Airconditioner leaking on drivers side
it may not be leaking it may be that the rubber hose that allows the heater case to drain is plugged up it is usually near the passenger side exhaust manifold and looks like a small rubber hose with a bend in it coming out f the fire wall and not connected to anything on the end sticking out.
Sep 23, 2012 | 2004 Mitsubishi Endeavor
Airconditioner cooling not workign despite three
I would check the system pressure. You can buy a leak detector. I would check all the fittings on the lines, around the compressor, condenser, and evaporator.
Mar 07, 2010 | 1998 Volkswagen Passat
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Trying to find out how many inches of belt i would need for a 97 crown victoria without the airconditioner is it a serpentine belt or drive belt
all the parts places i called said i wouldnt be able to get an accurate measure of the belt and suggested i get a airconditioner bypass pulley system that takes the place of the airconditioner pulley so i went and bought one and i will be putting it on today
Sep 15, 2009 | Lisle Serpentine Belt Tool
The air from the airconditioner and heater only will blow out the
Sounds like a vacuum leak. Check the vac supply on the intake manifold. Passenger side front of intake.
Jun 24, 2009 | 1997 GMC Safari
2002 Buick LeSabre Limited. Airconditioner cools
The dual air on this car has two temp control motors that are electronic. You need to have the car scaned at a dealer to see if it has a code for the left temp feed back circuit. If so you will need to replace the temp control motor for that side.Good Luck
Apr 30, 2009 | 2002 Buick LeSabre
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
2,605 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
