Question about Metabo Tools & Hardware - Others
Metabo sr358 plate removal
I am working on a Metabo 358 and I am trying to remove the bottom plate to replace the sandpaper clamp springs. How does the orbital plate eccentric come off the shaft after shaft bolt is removed.
  • Kevin O'Leary Jan 12, 2009
    Rowdy
    I am trying to remove he bottom plate, with the 4 screws out nad the center shaft bolt off. Teh eccentric is a under the rubber pad, which is removed, and the eccentric will not come off. It is a cast aluminum. Even with heat the eccentric will not come off. I must remove the bottom plate so I can replace one of the 2 sandpaper clamps that broke.
  • 2,176 Answers
Are you removing the plate from the top (4screws) or trying from the bottom. It appears that the eccentric is a loose press fit. I am looking at a breakdown but it is not really all that clear. I would suggest going to Metabotools.com and under downloads type in your model number which is 600358-42, the 6 is already in place so what I did is add a 1 to the end of it and found the tool. Let me know but did you also check the clamps for the reason. Usually the platen is sold as an assembly.
Posted on Jan 10, 2009
  • David Ford
    David Ford Jan 12, 2009
    Have you tried a screwdriver on either end alternately applying down force on the screwdrivers to pry the eccentric off. Also if you have applied heat you might want to take a look at the bearings. Did you look at the breakdown I mentioned it shows exactly what needs to be done. Let me know
How do I change the paper?
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.Refer more on custom essay writing service
Custom Essay Writing Dissertation Writing Thesis Writing with Free Draft...
Jan 09, 2016 | Tools & Hardware - Others
Ford focus front strut replacement
basically remove the wheel ( after placing the vehicle on jack stands). remove the bottom ball joint connection ( bolts or ball joint with a ball joint splitter) use 2 spring compressors and close up the spring mark one bolt in the engine bay at the top of the strut so you know where the unit goes on reassembly The bolts control the wheel alignment)undo the bolts and drop the unit out the bottom. undo the nut at the top and release the spring clamps. Lift the spring and top plate of the shaft. Undo the insert nut and remove out of the tube. Insert new insert and reverse the procedure. A workshop manual ( genuine or after market will have the procedure in full with photos)
Jul 25, 2014 | 2000 Ford Focus
The clutch will not disengage, can anyone out there help-thank you
If it has been sitting for a while, the clutch plates are rusted to the friction plates. Get ready to remove the exhaust, drain the oil, side frame, brake pedal and clutch cable. When you remove all the hex bolts use the bottom corners that stick out a bit to tap "softly" to get the cover loose. 4 bolts hold the springs, and after that one more nut and you can get to the plates. put the brake pedal back on to stop it from turning to break the nut loose. replace them or use some fine sandpaper to clean. ENJOY!!!
Aug 12, 2011 | 1984 Honda VT 500 C Shadow
Diagram for back brakes on a 1995 jeep cherokee sport
Brake Shoes REMOVAL & INSTALLATION Fig. 1: Use a brake cleaner to clean the brake surfaces 86749p23.jpg
Fig. 2: Using a brake tool, remove the return spring from the anchor pin 86749p24.jpg
Fig. 3: Remove the return spring and the adjuster cable guide 86749p25.jpg
Fig. 4: Remove the adjuster cable 86749p26.jpg
Fig. 5: Remove the shoe guide plate 86749p27.jpg
Fig. 6: Disengage the hold-down spring retainers from the hold-down pins 86749p28.jpg
Fig. 7: Remove the hold-down springs and pins 86749p29.jpg
Fig. 8: Pull the shoes apart and then . . . 86749p30.jpg
Fig. 9: . . . remove the parking brake strut and spring 86749p31.jpg
Fig. 10: Remove the shoes from the backing plate 86749p32.jpg
Fig. 11: Disengage the parking brake cable 86749p33.jpg
Fig. 12: Lubricate the shoe contact points — 10 inch drum brake backing plate shown 86749g41.gif
Fig. 13: Adjusting the gauge to fit the brake drum 86749g42.gif
Fig. 14: Adjust the brake shoes to fit the gauge 86749g43.gif
Fig. 15: Adjusting the drum brakes using a brake spoon 86749p35.jpg
CAUTION
Brake shoes may contain asbestos, which has been determined to be a cancer causing agent. Never clean the brake surfaces with compressed air! Avoid inhaling any dust from any brake surface! When cleaning brake surfaces, use a commercially available brake cleaning fluid. NOTE: A brake spring removal tool and a brake adjusting gauge are required for this procedure.
  1. Raise and support the vehicle safely with jackstands.
  2. If the brakes have never been serviced before, the drums will be held on the wheel studs with spring nuts. Remove the spring nuts and discard.
  3. Turn the adjustment starwheel so that the brake shoes are retracted from the brake drum and remove the brake drum.
  4. Install wheel cylinder clamps to retain the wheel cylinder pistons in place and prevent leakage of brake fluid while replacing the shoes.
  5. Remove the U-clip and washer securing the adjuster cable to the parking brake lever.
  6. Remove the adjuster cable, cable guide, adjuster lever and adjuster springs. Remove the return springs with a brake spring remover tool.
  7. Remove the hold-down retainers and springs, then remove the brake shoes. To install:
  8. Clean the backing plate with a brush or cloth. Place a dab of Lubriplate® on each spot where the brake shoes rub on the backing plate. NOTE: Always replace brake linings in axle sets. Never replace linings on one side or just on one wheel.
  9. Thoroughly clean and lubricate the adjuster cable guides, adjuster screw and pivot, parking brake lever and lever pivot pin with multi-purpose grease.
  10. Apply a thin coat of multi-purpose chassis lube to the mounting pads on the backing plate.
  11. Transfer the parking brake actuating lever to the new secondary shoe.
  12. Position the brake shoes on the backing plate, then install the hold-down springs and retainers. Don't forget to engage the parking brake lever with the cable.
  13. Install the parking brake actuating bar and spring between the parking brake lever and primary shoe.
  14. Install the self-adjusting cable, cable guide and upper return springs.
  15. Thoroughly clean the starwheel and lightly lubricate the threads with lithium based grease.
  16. Install the starwheel.
  17. Install the self-adjusting cam and lower spring. A big pair of locking pliers is good for this job.
  18. Check the surface of the brake shoes for any grease that may have gotten on them. If dirty, lightly clean with a piece of sandpaper.
  19. Adjust the brakes, install the brake drum and wheel. Lower the vehicle and test drive.
Aug 17, 2010 | Jeep Cherokee Cars & Trucks
Replace struts on a 1987 bmw 325e
YOU NEED TO REMOVE THE STRUT COMPLETELY USING COIL CLAMPS CLAMP THE SPRING AND REMOVE TOP PLATE UNDOO THE LARGE NUT ON THE STRUT ITSELF THEN PULL OUT THE INTERNAL SHOCK REPEAT THE PROCESS IN REVERSE FOR ASSEMBLEY
Sep 01, 2009 | BMW 325 Cars & Trucks
Kenmore dishwasher stock #16469 (Part #665.16469300) motor/pump made loud steady noise then stopped working. How do I remove motor/pump?
remove the D/W from power
remove the front bottom grille
reaching under the machine with a flashlight ;you will see a black rubber plug held on the pump bottom by a spring clamp remove the clamp with a spring clamp plier put your index finger in the pump and, carefully attempt to turn the pump impeller until it spins (the debris that was holding it will fall out
put everything back and, repower the machine
Aug 30, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
How to change bellows on Kenmore front loading washer
First remove the bottom kick plate at bottom. Then tear off the front of the bellows from around the door. Inside there is a big hose clamp holding the inside if it. Remove completely.
Now,put the inside on first, Tightening the inside clamp. Easy so far, right?
My trick to the outer spring:put a little liquid detergent or soap on out bellow where spring attaches,start at top and work it down and around, use needlenose pliers to help with hard part. Good Luck.
Mar 13, 2009 | Washing Machines
Need to replace door gasket
Remove the top cover by removing the 2 screws in the back.
Remove the dispenser drawer completely.
Remove the 2 screws on front of the panel where the dispenser drawer was removed.
Remove the screw on the right side behind the front panel.
Disconnect the wire harness behind the panel.
Starting on the dispenser side with your finger, pry forward the top of the control panel until it unsnaps.  Continue this all the way to the right and remove the control panel.
Go to the bottom filter door and remove the door.  Unscrew the one screw below the filter cap.  Remove the plastic insert covering around the filter cap.
Locate a small screw at the very bottom of the frame just below the filter cap and remove.  Sometimes there may be 2 but usually there is only one.
Open the door and locate the spring clamp usually located at the bottom of the door seal.  Remove the spring clamp.  This will loosen the front of the door gasket for removal from the frame.
On the right of the door gasket is the door latch assembly.  Unscrew the 2 screws and set the latch hanging by the wire harness.
Remove the 4 or 5 top screws holding the front panel assembly.  Once they are removed, the front panel will lift up and out.
NOTE!!!  THIS JOB REQUIRES 2 SPECIAL TOOLS FROM LG TO REMOVE THE SPRING CLAMPS ESPECIALLY THE REAR CLAMP.  THE SPRINGS ARE SET VERY TIGHT SO IT IS NOT EASY TO REASSEMBLY WITHOUT THE SPECIAL TOOLS.
Sep 23, 2008 | LG WM1814CW Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Tools & Hardware - Others Logo
286 people viewed this question
Top Metabo Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Metabo Tool and Hardware - Other Expert? Answer questions, earn points and help others
