Question about Sanyo Televison & Video
Greatings everyone. I have a Sanyo DP46819 LCD TV. I have a left side not showing the picture. The Back light is working you can see that it is if you look in the back vents of the TV. When you 1st tu
A buddy of mine gave me a T-con board to try and it didn't fix the problem. What are the odds of that 2nd T-Con being bad also?
  • 1 more comment
  • Tim Bourque Nov 28, 2012
    Here is a picture of my screen with the black and white strips on the left side.
    some say T-Con board and some say its the screen???? what is it?
    I have opened the tv to get to the T-Con and the ribbons look good. were the ribbons go from the T-Con board to the screen its in a tight place on the screen that i have to use a very small screw driver to release the tabs that hold the ribbon inplace. On the frame of the screen not the chasis of the TV should i seperate this frame to exposethe T-Con ribbon conector on the screen side?
  • Sanyo Master
  • 933 Answers
T-cons rarely fail but it is possible. Like BOZ said, I would check the flex cable connections from the t-con and LCD panel.
Posted on Nov 28, 2012
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
It is possible the flex cable that connects directly to the LCD is starting to work it's way loose from the LCD panel itself. It's more common for a board to go but if it's an model it has probably gone through a lot of heat cycles. Sometimes you can get lucky and locate the solder area of the LCD and gently push on the edge that connects both halves. If the picture jumps when you press down, it's becoming detached and there is no easy fix unless you have a new die solder/resin and cable for it.
    Problem Solver:
  • 7 Answers
T-Con board
3 Suggested Answers
  • 718 Answers
SOURCE: I have a 46" Samsung LNT4661FX / XAA LCD TV. My
Good fixes. Sometimes the connector for the cables running from the LCD to the T-CON do not make good contact. You might try moving them around to see if it affects the picture. You can even carefully disconnect and reconnect them.
I have come across one person that fixed a display by resoldering as many joints as possible on the main board.
When these boards are made they use a wave solderer and with the new RoHs standards and shoddy workmanship a lot of 'cold joints' are developing. If you do this, use RoHs compliant solder.
Posted on Feb 19, 2011
  • 915 Answers
SOURCE: I have the sanyo model
Your backlight controller is faulty and requires repair. It may be due to bad capacitors or faulty inverter transformers.
Posted on Mar 07, 2011
Electro-help
You need to specify the TV model and chassis to get meaningful and useful help.
Also you can check this:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
Mar 18, 2014 | Sanyo 42 in. LCD TV
Sanyo tv standby mode
Too little details here - need model, chassis, more specific behavior details.
This may help:
May 06, 2013 | Sanyo 42 in. LCD TV
Dp46819 color hoz lines left side only
are you certain they are horizontal and not vertical?
Feb 26, 2013 | Sanyo DP46848 LCD TV
My LCD Sanyo tv won't show picture and the green
PLEASE CHECK CABAL LINE FIST. SEE THE TV BACK SIDE AND ADJUST UR CABAL JACK.OR HAVE ANY DVD PLAYER PLEASE ADJUST UR DVD JACK SEE UR TV PICTURE.IF SHOW UR PROBLEM SOLVE OR NOT SHOW UR TV PANEL PROBLEM.
Dec 27, 2012 | Televison & Video
My 46" sanyo lcd tv screen was all black on the right side and got to where it shut off now it wont even come on
Specifying the model - and in case of Sanyo TVs the chasis - is critical for faster and proper diagnostics of such problems.
Here are a few points of reference, neither of which covers nearly completely the very wide Sanyo TVs line:
http://www.coppelltvrepair.com/productag/19/sanyo
Sep 04, 2012 | Sanyo DP46848 LCD TV
Sanyo DP46819 green ind. light comes on but no screen or audio
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Jun 07, 2012 | Sanyo DP46848 LCD TV
Televison & Video Logo
176 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
