Question about Lenovo G550 PC Notebook
My lenovo lcd sometimes dosent work
When i reboot my screen evreything works just fine but when i tuch the screen or move the computer/ the screen start to changing colors. i mean full solid red/green/.... with no picture. it keeps changing colors/ note that if i do not tuch it the picture is great i can ear windows trough the speakers so no problems there. please advise many thanks ori
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Hey, i think there exist the problem with the latch connecting the screen and board... anything of loose connection or internal damage kind of thing....
Posted on May 04, 2013
5 Suggested Answers
SOURCE: Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Posted on Dec 15, 2008
  • 12 Answers
SOURCE: Lenovo 3000 v100 keyboard problem
sound like a connector problem .. see this website for the removal instructions
http://www.lenovoservicetraining.com
Posted on Jan 08, 2009
Geekman
  • 32281 Answers
SOURCE: Startup Problem with Lenovo 3000 N200 with Vista
You would need to reinstall Vista together with the device drivers and programs to get a laptop functioning again.
You need to backup your data before you reinstall Vista but since you cannot boot up and get into Windows, you need to remove the hard drive and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. This computer should see this hard drive as an external hard drive (provided the hard drive is OK). You can now see the various folders and files, copy your data files to a USB memory stick or burn them to a CD.
Insert the hard drive back into your laptop and then install Vista.
Posted on Jun 21, 2009
SOURCE: lenovo G3000 38Q - built-in mic not working under
I believe the problem is that your mic isn't working properly so follow these instructions:
1: Go to control panel and click on "sound"
2: When the sound window opens click on "recording" you should find the built in mic there in the dialog.
3: Click on your built in mic and click on configure.
4: Then, click on "levels" and set the microphone level to 50 and the microphone boost to +20.0dB
If that doesn't work try doing a system restore.Or you could try restoring the defaults on the sound pref.
Posted on Jun 26, 2009
Lenovo idea pad 300 won't turn on. Red power light blinks 3times then switches off. Rebooting doesn't work. Tried different adapter. Power on Lenovo screen appears for 5 seconds then goes black.
Sometimes they 'crash' in sleep mode. Try hold the power button down for 10 seconds. This should make it reset. After the 10 seconds, release the power button. Then press it again to turn it on normally.
Oct 09, 2017 | Lenovo Computers & Internet
I have a Dell external display connected HDMI to my Lenovo Yoga. Worked fine until today, now Dell isn't getting a signal in. I know the Dell is fine, works on other laptops, so cabling etc. is good
I know you said the cable is good but try it on something else like the TV. If the laptop connects to the TV from the HDMI the the issue will more than likely be a driver issue. Try updating you BIOS on the Lenovo and check for other driver updates, sometimes they put out updates to fix little bugs like this.
Sep 14, 2017 | Dell Computers & Internet
Screen is not working?
If the screen is black, then with computer on, shine a strong flashlight on the screen at about a 20 degree angle (90 degrees would be pointing the light right at the screen). Move it around to see if any of the expected graphics (e. g., login request) are visible. If so, your backlight is not working, but everything else is fine. A backlight failure is usually due to a dead fluorescent tube, but sometimes is the result of a bad inverter. If you have an LED backlight, check the LED driver circuit first.
Jun 25, 2014 | Lenovo ThinkPad Tablet 2
My lenovo Y410 lcd screen is blinking a lot and sometimes the cursor also stops working. Sometimes half of the screen is filled with dark pink and green color spots and when the lcd screen is held tightly...
Welcome to FixYa!
It seems that you're having a serious display problem. One way to confirm this issue is for you to go to the BIOS screen of your Y410 and see if the problem would materialize.
Here's how
  • Shutdown your computer and disconnect any USB storage devices attached.
  • Turn it on and tap on the "F2" key repeatedly until you see a different screen
Once in BIOS, see if the discoloration/blinking issue is present. If it is, then I strongly suggest that you take this laptop to the nearest Lenovo repair center. If it's still in warranty, then the repair can be covered, otherwise, I'm seeing close to $300 for LCD replacement.
Hope this helps and Thank you for using FixYa.
Nov 07, 2010 | Lenovo 3000 Y410 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
I have Lenovo y410, win xp. my webcam isnt working
Here is the driver for XP for that Lenovo Y410 of yours, LN1CAM29WW3.exe , the camera name on it Lenovo Easy Camera
Download and install it and you will be fine!
Good luck
Nic
Mar 03, 2009 | A4tech Xmaster PK-835 Webcam
Dec 10, 2008 | Lenovo ThinkPad T61 Notebook
Monitor or pcu problem
It appears that your graphics card is defective. If the monitor works on your laptop and reinserting the graphics card did not help, I would suspect the card itself.
Aug 19, 2008 | Acer AL1716 17" LCD Monitor
Aopen monitor and a new Lenovo computer
resize the screen resolution to the lowest and change the monitor refresh to60 hz . then play with the refresh and then the screen resolution.
Jul 20, 2008 | Computers & Internet
Tuch screen not working
the connection of the control button of the lcd panel is cut....check the flex wire of the lcd
Jul 19, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Lenovo G550 PC Notebook Logo
93 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
