Question about HTC G1
Goole maps problem.
When using the maps application in the phone, I can't get traffic inforation displayed. I go to the map mode icon and switch between map mode, sattelite mode and traffic mode, it shows that I have selected traffic but the screen is exactly the same as map mode.
I can use the traffic function from the googlemaps site on the internet but that does not integrate with the gps function on the phone.
Anyone help cos T-Moble have no idea.
Karl
    Problem Solver:
  • 8 Answers
Hey did u hear about andNav http://www.navigadget.com/index.php/2008/09/29/does-t-mobile-g1-really-have-gps-navigation
Posted on Jan 12, 2009
G1 pairing problem
tomtom is coming out with software soon to be able to use your g1 as a gps device. theres apps on the market that let you view traffic updates just look up gps on the apps market and find one there. i believe google maps does traffic updates. you should get the docking station for your car it replaces expensive gps devices.
Aug 18, 2009 | HTC G1
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
HTC P3300 with Google Map
try using internal GPS...
let it be managed by Windows itself...
Do not set to manual selection...
I am using GPS on Google Map on HTC P3400 from 10 months...
Feb 18, 2009 | HTC P3300 Smartphone
Sat Nav, Online mapping not good
Check out the Terracrosser software, this uses Google maps but allows you to use downloaded maps. Terracrosser works on my S620 although I haven't been able to get my BT GPS unit to function properly with any mapping software. I have tried setting it to COM 6 as previously suggested.
Jan 29, 2009 | HTC S620 Smartphone
Google maps application will not work on unlocked F700 for at&t
i bet you are o2 pay as you go . :) , i think its the only operater that dosnt allow google maps . ring them and moan. :)
Dec 30, 2008 | Samsung Ultra Smart F700
HW6910 PDA - GPS Map problem
It needs to be in the same place as the map you have, but in a new directory ; e.g. "GB" as well as Southampton.
Easy way out to to load it using TomTom Home...
Dec 10, 2008 | HP iPAQ hw6515 Pocket PC
How can i get my gps to work
It's in the maps program under settings. Once it's activated you will get a warning message about the battery life going down when in use but it should deactivate once you are off of Google maps. You will see a satellite dish icon on the upper part of the screen once it is on.
It's works better in mapping mode than satellite mode as well. Due to the amount of time it takes to redraw the screen.
Nov 01, 2008 | HTC G1
T Mobile G1 GPS Problems
G1 Gps Problem Fix - I recently had the same issues with the gps giving me the location of cell towers instead of actual location. After looking around the forums, i found the fix and it worked.
Clear you maps cache by going into your application data.
Settings : Applications : Manage Applications : Maps : then push "clear data"
Make sure both your wireless and gps are turned ON
Turn off Phone
Take it outside somewhere that is clear of obstructions (like a large parking lot, or field)
Turn on phone
Once on, press maps
Let it sit in one spot for about 5-10 min, then press my location.
It should find you in just a few seconds. Mine took about 30 seconds.
This should fix most problems you are having.
Oct 26, 2008 | HTC G1
Activate GPS on HTC TYTN11
HTC tytn II, att tilt,Kaiser ( all the same products) have internal GPS chip installed just near the camera , so you need not buy anything else. Just get google maps app, a internet connection and try to find your self by using locate me feature on google map, the GPS chip will point you on map with very much accuracy.
Oct 06, 2008 | HTC TyTN Smartphone
HTC G1 Logo
104 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
