Question about Xerox WorkCentre 7525 7530 7535 7545 7556 Yellow Toner 006R01514
XEROX WorkCentre 7545 fax
Fax
  • 2072 Answers
SOURCE: Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
  • 24 Answers
SOURCE: Service Manual for Xerox WorkCentre m55. URGENT!
Does this link help?
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC_M55&Xlang=en_US&Xcntry=USA
Posted on Jun 10, 2009
  • 24 Answers
SOURCE: I have a Xerox WorkCentre 5638. How do I save
You cannot save the e-mail addresses on this unit except by creating a .CSV file and uploading it via CWIS under Properties>Services>E-Mail>Public Address Book. A link to the instructions is below:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=195,E=0000000001733361539,K=3118,Sxi=11,Case=obj(10395)
Posted on Oct 25, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Cleaned waste toner out but xerox 7545 wont ecept it says to replace waste tone
You didn't clean the bright plastic bubble at the upper inside end.
If dirty, machine thinks it is still full of toner.
Jun 24, 2014 | Xerox Workcentre 7545/PT 7545PT Color...
My xerox 7545 workcentre comes on, but it does not show the menu screen. it goes to fully on, but could not able to pick up menu screen.
Hello, The first thing you need to do it power down,unplug the workcentre and let sit for 2 mins. Plug back in and observe. If this doesn't work it will result in a call to your service provider and a field tech will have to trouble shoot the problem.
May 15, 2014 | Xerox WorkCentre 7545/P Copier
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre 7525 7530 7535 7545 7556 Yellow Toner 006R01514 Logo
150 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
