Question about Kitchen Ranges
Led control panel for jenn-air oven sve47600B does not light up
The led control panel for jenn-air oven sve47600B does not light up and constantly beeps. The range fan also began to run constantly. It is an electric oven. Is the problem the control panel or would it be more than that.?
    Scholar:
  • 160 Answers
Beeping sound coming from the control panel area with no fault code displayed in the Electronic Oven Control (EOC). The consumer can set the oven lock out feature and the beeping stops.
Possible open or shorted oven sensodprobe circuit, or oven control. The oven control will beep constantly when it detects a fault condition in the temperature sensor/probe circuit. This may be caused by a runaway heat condition, open or shorted temperature sensor/probe, or faulty sensor/probe connection or harness.
The technician should test the temperature sensor/probe circuit by disconnecting the P3 connector at the oven control board and then measuring the resistance between the two purple wires. The resistance of the oven temperature sensor probe should read the same as that of the main oven temperature sensor/probe. If the sensor/probe circuit and harness are good, then replace the oven control board.
Posted on Jan 10, 2009
    Sergeant:
  • 431 Answers
Can u tell in detail please
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Oven inop error code f7
This is your ERC ( electronic range control) that has gone out on this unit. We are factory authorized Jenn-Air service and parts supplies and we LOVE the Jenn-Air brands. Our house is full of Jenn-Air appliances, also.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we can next day air the correct part to you first thing Monday so you can start cooking for the holidays!
We answer our phones from 7 AM until 9 PM CST from Monday through Saturday and look forward to helping you to get cooking again.
Thanks, Ella
Nov 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air- model # SVE47600B
I was cleaning the oven and leaning on the oven door and now when I close the door it is hard to close
Dec 20, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
