Pavillion dv5 1235dx forgot password
Can i get it back to factory settings
    New Friend:
Yes
Posted on Nov 28, 2012
5 Suggested Answers
SOURCE: reset factory password on t61 lenovo
Pulling the bios battery does not work on the Lenovos - youll be wasting your time. Where did you get that information Jadestar - Ill bet you can't name one person for whom your solution works on these laptops!!???
Posted on May 21, 2009
  • 85 Answers
SOURCE: Forgot the admin password is there some kind of
insert a pd into USB port and click on "change passward" or "Forgot passward" option on the login screen of your system .
read and follow the instructions to recover your admin pass.
Posted on Mar 30, 2010
  • 150 Answers
SOURCE: have an inspiron 1440 forgot
If you have the restoration disks that either came with your system or have created them per the owners manual. If not, you could use a third part software such as kon-boot which is free to create a boot disk that will bypass the user password.
Posted on Jun 18, 2011
Geekman
  • 32281 Answers
SOURCE: i forgot my password and i need to know how to set
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Posted on Jul 03, 2011
What do I do if I forgot my password?
Well, if you forgot your password, you will need to completely reset the device to factory settings. There should be a recessed button on the back that is only accessible with a pin or paperclip. Press that and it will reset all of the settings to default.
Sep 02, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Forgot my username and password
There is usually a factory reset button located in a pinhole on the back where the connections are. Turn the router on and press the reset button for 5-10 seconds. This will clear all the settings including your password. You can find the factory password in the manual or online.
Mar 03, 2014 | Linksys Wireless-G Broadband Router
Forgot my windows ce password need to rest my laptop back to factory setting
Forgot windows password, we can use Windows Password Reset to reset our windows password.
The steps are:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password
So easy,right?
Jul 08, 2012 | Computers & Internet
I forgot my password to my dell latitude i need to restore it back to factory setttins i already have it took apart
Are you restoring back to Factory Setting simply because you forgot the password? Please tell me NO. If so, that is not what you want to do. Resetting to Factory Settings will cause you to lose all your documents, music, pictures & videos unless you have them backed up somewhere outside of the computer. If all you need is the password removed, try turning off your machine, then turn it on and immediately hit the F8 key repeatedly until you see the SAFE MODE option. Select Safe Mode and let it boot. When the log in screen appears you will see the account for which you forgot the password and the Administrator account. Select the Administrator account (hopefully you didn't password protect it and forgot it also). If you log in successfully with the Administrator account click Start/Control Panel/User Accounts. When you are in the User Accounts select the account for which you forgot the password, then select the option to Remove Password. Now reboot your machine.
Mar 15, 2012 | Dell Latitude E5400 Laptop
How to factory reset d-link dir-825
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Feb 02, 2012 | D-Link DIR-825 Wireless QuadBand Router
How to retreive Wi-Fi WPA2 password which I forgot?
Hi there.
If you forgot your wifi password, all you need to do is reset your modem. Doing this will restore your modem to it's factory settings.
Find the reset hole, could be on the side, front or back of the modem. Unfold a paper clip and push the reset hole with the paper clip. Hold it down for about 10 seconds or until it turns off.
When you turn the modem on, it is already back to factory settings and it will no longer ask for a password.
Let me know what happens.
Thank you!
Sep 16, 2011 | Computers & Internet
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Forgot my network key password
For wireless or to manage the router?
If you forgot the wireless key password, you should be able to get into the router through a web interface and get or reset the wireless password.
If you don't remember the password to manage the router itself, it should have a "Reset" or "Go Local" button the back of the unit. Press and hold that for about 5-10 seconds. This will set the unit back to factory defaults and you should be able to log in again to set up your wireless settings.
Aug 09, 2009 | Belkin My Essential (ME1004-R) Wireless...
Forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Mar 29, 2008 | Actiontec GT704WG Wireless Router...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
