Question about Edimax BR-6228nS 150Mbps 11n Wirless BroadBand Router/4 Ports Switch
Edimax BR-6228nS repeater cannot setuo
I cannot extend my nework can someone help me pleas it works until neworks have a diferent name when i var to rename edimax to linksys it stoped to work
  • Edimax Master
  • 2,219 Answers
The router does not have an extension capability. You need a separate device to act as a wireless repeater. See Manual.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6228nSnC/BR-6228nSnC_UserManual_v1.zip
Posted on Mar 03, 2015
  • 196 Answers
SOURCE: Edimax connection options
Make sure that when you connect, you?re signed in as ADMIN and not a USER. If that isn?t the problem, check in system preferences if the connection has to be secure or limited in any way.
Posted on Feb 22, 2006
SOURCE: edimax ar-7084
hi, contacted edimax and was told how to reboot the router without the disc, my original problem was a faulty filter on the telephone line which caused an ASDL failure. hope this helps
bill
Posted on Nov 20, 2008
  • 37 Answers
SOURCE: i need the xp drivers/cd
You should be able to download the driver from the following link:
http://www.updrivers.com/drivers/Wireless_Access/Edimax/EW-7126-Windows_2000_98_XP_ME/35602.html
Posted on Jan 03, 2009
SOURCE: need the xp driver/cd for edimax ew-7126 wireless lan pci card
http://www.edimax.com/en/support_detail.php?pd_id=174&pl1_id=2&pl2_id=49#01
Posted on Jan 05, 2009
govinda123
  • 2260 Answers
SOURCE: how to set up password for my edimax wireless
you want to secure wireless network.
is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to the router with the cable.check the ip address on the computer.open the router set up page.
you will find the option to make it secured.
Click here for more info
Posted on Dec 03, 2009
Can not connect to wifi edimax wireless br-6228ns
I have the same problem. I try it from 1 month. My model is BR-6428nS. How I know which my PIN is?
Aug 01, 2013 | Edimax Computers & Internet
Cant connect the wifi edimax wireless br-6228ns
Here is the manual on to set it up.
From the manufacturers website.
Try setting it up according to the manual. If you need help you can contact the manufacturrers technical help here. Support Services
Aug 01, 2013 | Edimax Network BR-6228NS Wireless N 150M...
Wireless g router 8 digit pin
There is a 8 digit pin number on the back of the router.
Windows 7 however has a problem and there is a solution here. http://www.edimax.us/html/Faq/PIN%20code%20not%20existed%20on%20the%20router.pdf
Apr 30, 2013 | Edimax BR-6228nS 150Mbps 11n Wirless...
I used to be able to torrent, now I can't. Error message is "No incoming connections"
try LAN cable in any point and change wireless security setting then find new wireless access point and try connect
May 19, 2012 | Edimax BR-6228Ns 150Mbps 802.11n...
Password reset
Do you know the current password? if so go to start > run command type IPconfig look under Default Gateway know that number. put that number into your web browser. Then from there use admin for your user name and 1234 in the password field from there go to your wireless settings and change the password
If you dont know the password just hit the reset on the back of the router for about 5 seconds and then follow above
Apr 24, 2012 | Edimax BR-6228Ns 150Mbps 802.11n...
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Nortel neworks voice
If your system is a Nortel Callpilot just log into your mailbox, then press 8, the first option "Record your name in the company directory" is what I think you're looking for.
Aug 05, 2008 | Nortel Meridian M7208 Corded Phone
Edimax BR-6228nS 150Mbps 11n Wirless BroadBand Router/4 Ports Switch Logo
450 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
