Question about Kenmore Dishwashers
How do I run (and interpret) the service diagnostic cycle on a Kenmore Elite dishwasher?
The dishes do not clean properly since the water is not getting heated as it was when first installed. I'd like to run the service diagnostics but I'm not sure how to interpret the results after it runs.
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Posted on Apr 10, 2008
SOURCE: Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Posted on Jan 30, 2009
SOURCE: Kenmore Elite dishwasher model 665.13793K600 not working
Couple of things you might check. Make sure that the soap dispenser is clean and not gummed up. What kind of cleanser are you using? If you are using the packets that melt upon contact with water, you might check to see if the wraping is sticking to the door. If the washer is loaded in such a way as to prevent a quality size stream of water to get to the dispenser it just may stick. This was happening to mine. I like to make sure the dispenser is dry, and the front of the racks by the dispenser are clear of any large article that would block the stream of water. Also, once I put the detergent in I start the machine. I do not let the detergent packet partially dissolve and then dry onto the dispenser thus preventing it from opening properly.
Posted on Aug 06, 2009
  • 3741 Answers
SOURCE: Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Posted on Aug 29, 2009
Should the inside of the elite dishwasher still be wet at the end of the cycle?
Martha,
If you are talking about having a small amount of water down in the bottom of your dishwasher, that is normal. There is a sump down there that needs to have water in it. If you are talking about having water on the walls, that is probably just condensation from the cycle when you run the heater. Try cracking the door after the cycle is done to let the excess steam out of the dishwasher and that may eliminate the water on the walls. Hope this helps!
Apr 03, 2015 | Kenmore Dishwashers
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher is not cleaning the dishes. Both on full service wash and 1 hour wash.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 18, 2011 | Kenmore Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
My kenmore elite leaves food all over my dishes and utensils when the cycle is over. what would the problem be
Try rinsing all of the food off the dishes before u put them in the dishwasher, also run the hottest water u can into the sink before u start the dishwasher.
Mar 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
27 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
