Sharp MX-2300N Color Copier Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code L4-31
My mx2300n is giving me error cod L4-31...what does this mean and how can i correct the problem.
Can this error be reset so i can continue printing even for a couple hours?
Anonymous
Level 2:
Novelist:
  • Expert 126 Answers
  • Posted on Jan 12, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
126
Questions
Helped
102114
Points
300
The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. The fan is one of the two located over the right side door.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5957
Points
Replace the exit fan
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P.
14 pages
HOW CAN I RESET ERROR CODE L4-30 ON SHARP MX2300N
The error means the Hard Drive fan motor is not turning. It will clear automatically by turning off the main power switch, but will keep triggering an error at startup if the fan is still having problems. you may be able to use canned air to blow enough dust off of the fan to get it running again. If standing at the copier the Hard drive is on the right side of the machine try blowing air in the ports on the rear of the frame. We always make sure to use non static canned air. If it will has problems you need to pull the Main Board and the fan and HDD is on the back of that. It only takes 4 screws to get out.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Mx2300n error code u2-30
Try this #, Interrupt,c,interrupt
use the ten key pad type 16 press start
ok
start
interrupt
ca
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
38helpful
5answers
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
3helpful
3answers
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
15helpful
2answers
Error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Error Code: E7-21
plaese hepply this problem
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
