Question about VinoTemp (VT60GNV) Wine Cooler
VinoTemp VT60 The Sears repairman said it was a defective switch controlling the compressor, and that he couldn't get a replacement. The problem was NOT coolant leakage. Now what?
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20 from AppliancePartsPro
First, unplug the wine cooler and take off the back panel. The back panel is held into place with several philips head screws.
Step 2:
Locate the compressor. You'll find the compressor in the bottom left corner of the VT-60 as viewed from the back. You will see copper tubes coming out of the compressor. These tubes carry the compressed refrigerant to the evaporator assembly. Be careful not to crimp or damage the copper tubing.
Step 3:
Find the black plastic cover to the left of the compressor. This cover is held into place with one philips head screw. Remove the screw and remove the cover to find the PTC start relay.
Step 4:
The relay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Slide the relay on the connector pins, reattach the blade connector, reattach the black pastic cover over the relay, reattach the back panel onto the VT-60 and you're done.
Posted on Dec 16, 2012
  • SamJ Dec 18, 2012
    It looks good so far -- I've found the items mentioned, and am waiting for the part. I'll see if it works! Thank you!
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
My vt60 winw cooler doesnt cool , it will show the degrees you want to set it at then few seconds later it goes back to the room temp. of 76...also makes clicking noise to start compressor then again a...
Sounds like the compressor is frozen - sound you hear is the clixon a special sort of resettable fuse on compressors. When they do not start or overheat, it kills the power - when it cools power is restored until it reheats again and .......................
Use ammeter to confirm this - it will show a much greater than normal current draw.
Apr 22, 2014 | VinoTemp VT-60 Wine Cooler
Need to replace compressor on vinotemp wine coooler
Return the compressor and buy another wine cooler. This work is too complex for people that do not do this every day, Thanks Sea Breeze
Nov 19, 2012 | VinoTemp VT-60 Wine Cooler
We have our unit in mexico and it has been working perfectly since 2004 up until today. As of today the lights are on but it is not cooling. I try to turn the temp down but it just flashes and then shows...
Here is the link to the main Vino Temp Online Support page with all the service manuals, troubleshooting guides and user manual.
http://www.vinotemp.com/Service-Support/Troubleshooting-Repair.aspx
Here is the direct link to the Troubleshooting Guide:
http://www.vinotemp.com/Resources/Documents/VT60.pdf
And here is the direct link to the Detailed Service Manual:
http://www.vinotemp.com/Resources/Documents/SERVICE_MANUAL_FOR_VT182.pdf
If you have a digital multimeter (voltmeter) and a screw driver then you can do most of the troubleshooting yourself. You should be able to tell if it is a controller board problem or a refrigeration compressor problem just by following the instructions in the guides.
If it is a control board problem you should be able to fix it with just a soldering iron, or if you need new parts, they should be available on Ebay.
If the problem is with the refrigeration compressor then any refrigeration technician (even in Mexico) should be able to fix it. Especially if you provide him with the service manual above.
Good luck and please comment back and rate if this was helpful or if you need further assistance.
Thanks.
Joe.
Feb 12, 2011 | VinoTemp VT-60 Wine Cooler
I have Vinotemp wine chiller model number VT-21TEDS-2Z. It is Dual zone and the bottom zone temperature is to low. I set it to 60 but it is at 49. The temperature controller does not seem to control it.
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 07, 2009 | VinoTemp (VINO-24GN)
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
My Vinotemp VT60 makes a clunking sound
You may want to contact Vinotemp's customer service @ 800-777-8466... you may need a new compressor
May 06, 2009 | VinoTemp VT-60 Wine Cooler
Vinotemp wine cooler won't cool
It sounds like your control module is bad. Vinotemp does list the replacement part as available at a cost of around $35
Nov 14, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
480 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
