Question about Microsoft Windows Live Messanger
Windows live messenger error code 8e5e0408
I have just loaded the new wlm and now iam unable to sign in to it of my desktop i have tried web messenger and i can sign into that i have also tried turing of my fire wall that didnt work my wireless router hasnt got a fire wall. iam not very good with computer can you help please
  • 11 more comments
  • Jota2k
    Jota2k Jan 16, 2009
    I have the same problem after installing WLM 2009.
    I deleted the folder from windows registry exactly as "r_farooqui" said, but (for me) it's not enough. I'm still getting the same message: "Signing in to Windows Live Messenger failed because the service is temporarily unavailable. Please try again later." Error code: 8e5e0408
    Anyone with another solutions?
    []'s,
    Jota
    PS.: I'm using Vista (32-bit)
  • Anonymous Jan 21, 2009
    i did tht nd it still dunt work :(
  • Anonymous Jan 28, 2009
    Same isse here. Though I do notice that if I sign in using web messenger and then try live messenegr, it actually signs me off the web messenger. I am using Norton 360 v2 beta. I have removed all the disallow rules and added a rule for msnmsgr and for port 1863 and still no luck.
    Going to try uninstalling Norton 360 and see if that resolves the issue. Completely disabling it and windows firewall didnt help. Live messeneger works on another machine so i know it's not router or switch related
  • Anonymous Feb 11, 2009
    its when i started using new msn and it signes in other msn adresses >:(
  • Anonymous Mar 17, 2009
    i think it has somethign to do with downloading movies or simalar, maybs by terminating bitspirit or bittorrent it may work
  • Anonymous Mar 23, 2009
    I upgraded my msn to a windows live 8, but then it says error : 8e5e0408 every time i try to sign in....please help me
  • Raioh Apr 02, 2009
    FFFFFFFFFFFFFFF WHY IS THIS HAPPENING!
  • Anonymous Apr 13, 2009
    I tried solution 2, i tried deleting my cache, i tried goin into regedit.
  • Anonymous Apr 22, 2009
    error code
  • Anonymous Apr 23, 2009
    #2 didnt work for me
  • xx-ami-babes Apr 29, 2009
    wont let me signe in to msn messenger however i am connected to a wireless route connection
  • Anonymous May 22, 2009
    it' the same problem
  • Anonymous May 24, 2009
    how do u backup your user directory under c:Users%username% ?
Check your event logs running C:\Windows\System32\eventvwr.exe
If you see lots of wlcomm errors under Windows Logs/Application, that means wlcomm has no access to your user directory.
To solve the problem:
1. Back up your user directory under c:\Users\%username% just in case
2. right-click on x:\users\%username% and go to properties
3. go to security tab and click advanced
4. Change the permission set to the following:
Type Name Permission Inhefited from Apply To
Allow %username% Full Control <not inherited> This folder, subfolders and files
Allow SYSTEM Full Control <not inherited> This folder, subfolders and files
Allow Administrators Full Control <not inherited> This folder, subfolders and files
Make sure you uncheck the "include the inheritable..." and "replace.." checkboxes.
Click OK and let it run.
Now you should be able to log on to Messenger.
Posted on Jan 30, 2009
TRIED ALL THESE ON HERE WITH NO LUCK SO I JUST WENT TO
HKEY_CURRENT_USER\SOFTWARE\WINDOWSLIVECONTACTS
AND DELETED ALL KEYS FROM DATABASE AND ME FOLDERS BUT NOT THE TOP DEFAULT ONES. WORKED FOR ME ANYWAY
Posted on Dec 17, 2009
  • noddstafcuk Dec 17, 2009
  • 827 Answers
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
  • rachel10
    rachel10 Jan 29, 2012
    Wow! Thanks for that! It's the best answer for that question I did! ...In other seaching on the other site!!!
ASK YOUR MOM !
Posted on Feb 17, 2009
Hi umm question about solution #2.. how do I open the user directory and how do I back it up? Sorry, I'm kinda confused I'm a newbie..
Posted on Dec 15, 2009
None of these work help !
Posted on Apr 05, 2010
Solution #2
Thank you very much
Posted on Apr 14, 2009
Solution #2
The second is true, thank you very much
Posted on Apr 07, 2009
The reason of the problem is unknown but the only solution is the restoring (Bo-Back) the Windows. To do this, go to Control panel and choose the Restore Windows.
Posted on May 08, 2009
Yes SOLUTION # 2 is work
Posted on Jun 28, 2010
Solution 2 worked 4 me. many thanx =))
Hellp
Posted on Sep 13, 2009
Solution #2 Wow thanks finaly I can log
Posted on Sep 20, 2009
ช่วยบอกวิธีแก้ Error code: 8e5e0408 หน่อยนะค่ะ
I cant open my msn due to the error code 8e5e05f6 Alain.crabos@hotmail.com
This should be able to solve your problem - hi
=? try this
close MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Mar 23, 2010 | Microsoft Windows Live Messanger
Will sign in, but signs out after a few seconds
try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Hope I helped Dr Reed
Nov 14, 2009 | Microsoft Windows Live Messanger
After signing into Messenger the program either says cannot connect or if it does connect it does for a short period then disconnects, with log in required to reconnect etc. Error Message States App Name:...
=? try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Hope I helped MSN expert Dr Reed
Oct 26, 2009 | Microsoft Windows Live Messanger
Why wont windows live messenger down load
lose MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Oct 12, 2009 | Microsoft Windows Live Messanger
My windows live messanger signs in for at least 6 seconds before it closes completely ... theres no error or anything it just closes before i can chat with anyone or anything its really annyoin ive...
=? try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Aug 15, 2009 | Microsoft Windows Live Messanger
Error code in windows live messenger 14.0
Try to clear the cache
C:/users/%USERNAME%/contacts/%YOUREMAIL%
C:/users/%USERNAME%/appdata/local/Microsoft/Messenger/%YOUREMAIL%
Delete these two folders and then restart Windows Live Messenger.
May 06, 2009 | Microsoft Windows Live Messanger
Hi I am desperate
Please try this. Delete or rename the following directories:
and
where %USERNAME% is your username in Vista and %YOUREMAIL% is the email you use to connect to WLM.
Best regards,
Zizzler
Apr 17, 2009 | Microsoft Windows Live Messanger
My msn messenger 9.0 signs out automatically by itself ..
=? try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Feb 22, 2009 | Microsoft Windows Live Messanger
Error code 81000451 how to fix??
i believe this is a window live messenger error, they already claim that thiers a problem with their wlm release but you can try this fix from microsoft web site
Nov 18, 2008 | Computers & Internet
Msn messenger error code 81000306
Windows Live Messenger error code 81000306 Problem description When you start Windows Live Messenger you cannot sign in, and you get error code 81000306 along with the message:
We were unable to sign you in to Windows Live Messenger, possibly because of a problem with the service or with your Internet connection. Please make sure that you are connected to the internet.
Error code: 81000306
Oct 18, 2008 | Computers & Internet
Microsoft Windows Live Messanger Logo
35,829 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
