Question about Dell Inspiron 8600 Notebook
Broadcom driver will not load
Inspiron 8600 running Windows XP Home
Machine had liquid spill on keyboard. Keyboard was damaged as well as one memory chip. Machine is running with only one memory chip installed. Running on AC adapter.
Starts and runs fine except that the onboard RJ-45 does not work. Device Manager reports that the device cannot start. It has a yellow exclamation point.
Administrative utilities reports Event Code 5008 - invalid network address.
Dell diagnostics reports Error Code 3B00.0788 - "EEPROM checksum failure. Expected 009Fh received 006Fh"
I have re-installed drivers from the Dell Resource CD, from Dell Support, and Broadcom, with no change in status.
FYI: Battery is discharged, with flashing yellow "fatal error" lights, and RTC battery is also dead.
I downloaded DOS diagnostic program from Broadcom that will let me re-program EEPROM, but I do not have the "eeprom.bin" file that I need to do so.
Any advice would be appreciated.
  • 43 Answers
Its probably short circuirt
Posted on Jan 10, 2009
  • no1coolfool Jan 10, 2009
3 Suggested Answers
  • 3940 Answers
SOURCE: Broadcom 440x driver won't load
if you are getting a broadcom failure of the motherboard after a chapagne spill on the system, there is a good likelyhood that the controller chip for the motherboard is damaged.
If the system is POSTING and booting normally aside from the Network adapter, I'd try using a PCMCIA or USB NIC to replace the onboard NIC (Disable on-board in BIOS) If the system is manefesting other errors, then a replacement of the motherboard would be warranted
Posted on Jan 11, 2009
  • 3940 Answers
SOURCE: Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Posted on Jan 25, 2009
Dell inspiron 1525 functions keys are not working
The two most common input devices for the Dell Inspiron 1525 are the keyboard and mouse.
Although the mouse is an almost indispensable tool in navigating through programs and websites with your laptop, the keyboard offers quick shortcuts to open and manipulate files and information.
An unresponsive keyboard can indicate a deeper problem and require troubleshooting to narrow down the cause and find the proper solution.
Laptops are collections of complicated computer components and sometimes a file or two can become damaged and affect the way the machine behaves.
The first action to perform when things aren't working right is to reboot. When your laptop restarts, it essentially resets all the files and programs to the "starting" position and corrects any small errors that may have occurred during the last session.
Eliminate Conflicting Hardware
With an almost unlimited number of accessories, programs and software available for your 1525, it's possible something else installed on or connected to your computer is interfering with its ability to properly communicate with the keyboard.
Shut down the laptop and disconnect everything attached to it.
Power up and test the keyboard.
If it works, start reconnecting each accessory, one by one, until the keyboard stops working. You've found your culprit.
Try External Keyboard
To determine whether the problem exists in the keyboard itself a hardware problem or with the software that controls keyboard function, attach an external keyboard and see if it works.
If it does, the problem with your 1525's keyboard may lie in the keyboard itself, such as a loose cable.
If the external keyboard doesn't work, the problem may lie with the operating system's software that controls keyboard function, such as the drivers.
Update Software
Sometimes a laptop will stop functioning properly due to out-of-date drivers or other software. Always check Microsoft's website for any updates available for your operating system and check Dell's website for updates to the drivers and BIOS installed on your system.
In many cases, installing the latest updates will help correct issues and keep your system working smoothly and efficiently.
Check for Damage
Physical damage, such as a liquid spill and short circuits, can prevent the keyboard from operating properly.
Any amount of liquid spilled on your keyboard can cause a short circuit to the components and a sticky beverage such as juice or soda can cause the keys to stick and become unresponsive.
Clean the spilled liquid from under the keyboard fix sticky keys.
Laptop repair shops can do this for you if the task is out of your comfort zone.
Hope this helps
Oct 23, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
How do i know if a motherboard is burned out after a liquid spill
what liquid was spilled into the keyboard ? water will dry out in a few days, but if it's soda then the motherboard/cooling fan will have to be cleaned
Jun 10, 2012 | Dell Inspiron 15R Laptop
My inspiron mini 1018 notebook's keyboard is not working properly. The left shift key appears to be stuck and I really having a hard time using the whole keyboard. I remember having spilled a few drops...
When water spills into a notebook, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you might have to replace the keyboard.
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
My keyboard is not working. I cant type in work not even in internet
Function and f7 key is its locked mouse pad or
refix keyboard and touchpad
conectors
Jul 08, 2010 | HP Mini 1000 Netbook
I have a dell inspiron I545 (I is a one, you will understand) Sometimes the left side of my keyboard acts up and affects the Q, A, and Z keys as well as the one key. This is annoying seeing as I write a...
Assuming the keyboard is clean and in good order it could be the ribbon connector, connects the keyboard to the motherboard. It may have worked loose.
Your user manual should give enough info on how to lift your keyboard. The ribbon connector socket has a slider on the back which needs lifting, Carefully slot the ribbon home, press the slider back down.
Mar 14, 2010 | Dell Inspiron 1545 Notebook
Some keyboard button not workin on dell laptop
Did you spill any liquids into the keyboard? If you did you may have damage the keyboard PCB and it will need to be replaced. One thing you can try to do is to first take a picture of the keyboard so you know where the keys go back to that you removed. Then use a small screwdriver to remove the non-functioning keys. Be very careful and do not use too much force or you may damage the key. Inspect the inner buttons and see if they are sticking. You can use a cotton swab or q-tip and rubbing alchohol to try and clean the inner part of the keyboard. Sticky liquids can cause the inner keyboard buttons to stick and mal-function. If the keyboard PCB is damaged you can either replace the keyboard or buy a usb keyboard to use on the laptop. The OS should recognize the keyboard after you plug it in.
Oct 13, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
Jan 10, 2009 | Dell Inspiron 8600 Notebook
Broadcom 440x integrated controller drive will not load
...Others may DISAGREE with this repair, but I have done this on countless laptops with a SPILL...
This is a ..(LAST RESORT) fix...
remove the KEYBOARD, rinse THOROUGHLY under gaucet, while briskly wiping key surface with 2" paint brush... Shake dry. wrap keyboard in a BIG BEACH TOWEL, place it in SPIN DRYER, set for SPIN CYCLE (only), and.... let 'er go... Then AIR DRY it overnite, reinstall.
... If MoBo wasn't also damaged by spill, this may be your answer !! Doug R.
Jan 10, 2009 | Computers & Internet
Dell Inspiron 8600 Notebook Logo
246 people viewed this question
Alun Cox
