Question about Stanton STR8-100 Turntable
Needle skipping towards end of record
I've recently pulled my Stanton str8 100's out of storage. Everything works fine aside from when the needle gets towards the end of a record and it skips back. Perhaps this is something to do with the anti-skate not working...?
  • dan c Nov 28, 2012
    it seems like the tone arm was a bit stiff in getting to the end of the record and a bit of gentle easing it to the side seems to fix the problem.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Stanton Master
  • 924 Answers
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 10, 2013
3 Suggested Answers
futurework
  • 70 Answers
SOURCE: Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
Posted on May 09, 2010
Testimonial: "thanks a lot i've tried the switch in both positions but it could easily be the cable which is not hard wired!"
  • 6771 Answers
SOURCE: I have the stanton t.52x
The turntable is the problem, possible causes motor, flat belt is stretched or direct drive issue, needs re-greasing.
Posted on Jan 02, 2011
Record continously skips after 4 or 5 seconds.
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
May 12, 2013 | Crosley Cr6001a Turntable
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
Set timing to stop skipping
here are some suggestions
Skipped stitches
Nov 12, 2012 | Singer 20U73
My machine is skipping stitches i have dusted it, rethreaded it, changed the needle and still it skips
try these suggestions and see if they help
Skipped stitches
Oct 17, 2012 | Janome Memory Craft 9000 Computerized...
Stanton STR8 150 turntable right output not working
Check the connections at the rear of the cartridge. Something may have worked loose while in storage
Oct 02, 2012 | Stanton STR8-150 Turntable
The thread is kinking and braking at the needle's eye opening and skipping.
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Skipped stitches
Sep 15, 2012 | Juki Sewing Machines
Singer esteem ii wont sew after the needle wouldnt go down and got fixed. when it does sew it skips stitches. what do I do?
Skipped stitches
if you can send me the model number of the machine,, I'll see if
singer has a free downloadable manual
Sep 11, 2012 | Singer Sewing Machines
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
My athena is skipping stitches. It's new to me and
Has the needle become blunt/burred by striking a pin or just using it for a while? Blunt needle will cause skipping. A needle needs to be changed after 4-6 hours of sewing to obtain quality stitches and it is easy to forget and not change one. If you can hear squeaking or popping sounds this is often a blunt needle.
Or if you are sewing knit fabrics with a regular needle, this will also cause skipping as the needle will deflect off the stretch fabric fibres. You need to use a ball point needle for knits.
The other possibility is that the timing is out but if it was just checked out by a tech that is unlikely (Unlesss you've had a jam up and struck the needle onto a foot or something).
Start with the needle though, its the most important bit.
Sep 06, 2011 | Singer Sewing Machines
Stanton STR8-100 Turntable Logo
130 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
