Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator I have a Whirlpool fridge model# GD5LHGXKB01 Serial# SL5157033 stopped cooling both freezer and fridge. Fan working, condenser hot. Cleaned black coils still not cooling. Condenser only comes on for 15-20 seconds then stops and then will come on 1-2 minutes later for same 15 seconds. I removed the back panel inside the freezer and there is no frost buildup at all. Please let me know what is wrong or what should i do thank you Jun..
  • juntot88 Jan 14, 2009
    I did change the overload/relay and now its working
    thanks for the help
Iam refrgeration mech have one now doing same thing put piercing valve on found that cop tube is blocked have found other refrigeraton units using 134a gas blocking cap tube systema
Posted on Jan 13, 2009
  • Whirlpool Master
  • 2,651 Answers
You can try replacing the overload relay mounted onthe side of the compressor ( kit number 4387835) sounds like its gone bad, trying to start yor compressor, but tripping off on overload.
Posted on Jan 12, 2009
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Whirlpool refrigerator model # GS5SHAXSLOO: Freezer works fine. Cool air not getting to the refrigerator area. Evaporator fan is working properly.
Hello there,
When your refrigerator tends to be running perfectly fine, but your fridge or freezer compartments are not cooling, then it means there is a problem somewhere inside the unit.
The problem could be caused by either a blocked condenser coil, or no more freon gas in the refrigerator. You need to clean out the condenser coils then refill the freon gas and your refrigerator will be in good condition once again.
Ensure your thermostat is functioning properly also.
Hope this helped you solved the problem.
Feb 06, 2012 | Refrigerators
Freezer works fine, but fridge won't stay cool. I replaced the defrost timer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
How about the fan at the condenser??? Is it running??? Is air being circulated from the freezer to the fridge...if not then find out what is stopping it...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 12, 2010 | Maytag Admiral Top-Freezer Refrigerator
Whirlpool model works but no
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jul 31, 2010 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer not cooling enough
Check the condenser coil and clean it if it is dirty. It is located under the machine behind the grill in the front, or in the back of the machine near the compressor depending on the make and model. Also make sure that the condenser cooling fan near the compressor is working. If the refrigerant is not cooled properly in the condenser the system will run hot and not cool properly inside the freezer.
If this does not help your problem, you will probably need a refrigerant technician to check the system. A rule of thumb for refrigerator repair, Freezer working but Fridge warm = airflow blocked inside the unit somewhere, Fridge cooling but Freezer too warm = refrigerant problem. This is usually a major problem that will cost too much to repair than is cost effective . Check your owners manual for warranty information. Look for coverage for the "sealed system". This is usually 5 yrs but can go much longer depending on make and model.
Let me know what you find out. Please post the model and serial numbers if you have any more questions and I will try to help.
Thanks, Mike
May 10, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
206 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
