Question about GE 32GT660 32" TV
Can't access Video Channels.
I'm trying to use my DVD player, but I can't access video channels. When I hit Channel Down on channel 2, it goes to 13.
    Problem Solver:
  • 14 Answers
Try hitting the input button on your remote.
Posted on Jan 10, 2009
How to get channel 4
You have to go back to the setup screen and scan for channels. Then you need to have a signal present for channel 4 so that the scan finds that channel. Note that if it is a unit that is not digital then it wont find channel 4 for broadcast. If it is digital and you are hooking something to it like a video player then it wont see channel 4 if the player is not digital.
Dec 08, 2014 | Sharp 13" Tv Model No. 13n-m100b
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
Admiral TV model GRD15272 video/dvd
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
May 12, 2010 | Emerson Televison & Video
How do I RECORD FROM A CAMCORDER TO THE DVD SIDE OF THE UNIT
  1. Connect the camcorders yellow, red, and white (Audio/ Video) to the input on the back of the combo called AV1 or Video 1.
  2. Then turn the channel on the DVD recorder to AV1 or Video 1. (A couple channels down from channel 2)
  3. Make sure camera is in VCR mode and hit play on camera
  4. You should see your camera video on your TV and rewind to the place you want to start recording and hit stop.
  5. Put an empty DVD in recorder and hit Rec. Button (usually red)
  6. Then hit play on your camcorder until you would like to stop
  7. Then hit stop on your DVD recorder and each section like this will be another chapter.
Good Luck
Oct 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
RCA model F27688-attempting to hookup new VHS/DVD player.
you will need the orignal remote to do this either hit the av button or game or input select button!
Jan 24, 2009 | Televison & Video
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
64 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
