One program running will cause high cpu usage and many svchost running.
SOURCE: memory of the Gateway - Laptop with AMD Turion? 64 X2 Dual-Core Mobile Technology TL-60
ok..and what is your question here?
SOURCE: My AMD Athlon(tm) X2 Dual-Core QL-64 by Gateway
"under the same modem" .. you mean connected to the same router?
if you are using an external USB modem, try a different cable -and keep it short. I can't think right now of any clear causes of this problem other than a bad USB (or too long) cable (which can cause exactly this problem).
possibilities.. could be a cordless phone, cellular, wireless mouse/headphones/controller, bluetooth .. many of these devices connect with their receiver regularly and use almost identical fequencies which interfere.
Doubt it is a network conflict -where someone else has the same IP address. You could try setting a manual IP address too..
good luck!
