Bsr turntable repair manual - Audio Players & Recorders
2 Suggested Answers
Grubhead
  • 5487 Answers
SOURCE: 1960s stereogram.bsr turntable turning to do fast.
If I can understand you right, the turntable is running fast. I don't think you need a new motor, generally the deck will run slow if the motor is knackered (or not at all). What you need to do is remove the platter, you will find a horseshoe bracket holding it on at the spindle (it may be covered up so you wil have to remove the cover part often a silver disc). The most likely cause will be the rubber idler tyre being worn damaged etc or out of place. There could be grease dirt or something else causing the problem.
Posted on Mar 26, 2010
Testimonial: "excellent thanks"
Hey there, After a power outage the motor that drives the platter "BSR turntable" does not function. Is there a fuse or some other likely suspect?
If the motor is directly connected to a mains supply then the chances are that when power was restored it burnt out or damaged the motor itself. Following the mains lead into the unit should answer where the power goes. If it goes to a transformer and it's associated power supply the problem will be found there.
Nov 07, 2016 | Audio Players & Recorders
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 12, 2015 | Audio Players & Recorders
I need a service manual for the BSR McDonald CA 50 turntable
BSR tended to make old style turntables, ones with a 78rpm speed on. I don't the model in question, but if it is a one of these, there's not much to them. Basically a rubber tyre runs inside the rim of the platter, while the tyre is pushed on a mains powered motor, in at least 3 different positions (depending on the speed). The tyre moves up and down depending which speed is selected.
Speed faults are caused by either a bad motor, or muck, oil, or grease in it.
A faulty tyre that is worn and doesn't push on the motor or platter anymore or not hard enough. Plus of course tyre height setting wrong.
Nov 08, 2015 | Audio Players & Recorders
I have a BSR C197 Turntable that won't switch from "off" to "on". It just sticks on off. Everything turns manually, but I cant move the little lever from off to on.
You will need to open the deck up from underneath. This should reveal some mechanical cause as to why the switch does work.
Aug 24, 2013 | Audio Players & Recorders
Mar 25, 2010 | Audio Players & Recorders
114 people viewed this question
 Grubhead
Grubhead
