Question about Fusion Commercial Fusion 512FC 8 oz Heavy Duty Countertop Popcorn Machine
Need thermaster fuse for popcorn machine - Fusion Commercial Fusion 512FC 8 oz Heavy Duty Countertop Popcorn Machine
My popcorn machine made a pop sound then it lost all power. Is there a fuse in the FunTime Popcorn machine?
Have you tried any other electrical equipment in the plug? If the outlet doesn't have power it's possible that the GFCI popped in the outlet and needs to be reset. Just the first step in a troubleshooting procedure. I can't find any mention of an internal fuse on the unit.
Jan 25, 2018 | The Kitchen Appliances - Others
Need diagram of 4081 gnp 8oz kettle and parts lists
I am sorry, That company does not have manuals, and there are no replacement parts for sale.
Dec 27, 2014 | Dtx International Great Northern 6005...
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Will not heat up and pop
Your power cord I would follow into the machine and hunt for a broken wire or a blown fuse possibly. Most pop corn makers are just about like a coffee pot. They have a klixon to control the temp and a couple of bullet fuses in line to prevent over heating. All of which is loacted on the base of the kettle. I wish I could be there to help ya get that popcorn popper working. Feetball season is nearly upon us.
Contact the makers
Aug 05, 2012 | Nostalgia Electrics KPM-508 Popcorn Maker
Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Jul 23, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
Part for Echols popcorn machine
I Have A Echols Popcorn Popper and Would like to know how old it is the serial no. is 86P101
Feb 28, 2009 | Cretors Goldrush Popcorn Maker
Fusion Commercial Fusion 512FC 8 oz Heavy Duty Countertop Popcorn Machine Logo
197 people viewed this question
Top Fusion Commercial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Fusion Commercial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
