Question about Panasonic Lot Of 10 Hac Vb-44223a-g Dbs 22-key Lcd Speaker Phone Telephone
How to turn of dnd/cf button on panasonic digital phone
4 Suggested Answers
Centernet
  • 38 Answers
SOURCE: DND button will not turn off
Depending on how your system is programmed, you might be able to turn it off by pressing it. Otherwise, you might have to press it and dial a code number, which also can vary from one installation to another, but I would try "0"
Otherwise, it can be programatically corrected by your installer if the system got "stuck" or something.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
cnavarro
  • 2460 Answers
SOURCE: I have an older model Panasonic Digital phone stuck on DND
Even the older Panasonic phones had numbers stenciled in the plastic, but it's immaterial because the programming is in the cabinet. Since you can't find it, this is just a shot in the dark. Try 710#, 7100, 70#, or just try pressing the FWD button and dialing ZERO.
Carl
Posted on Jun 01, 2009
cnavarro
  • 2460 Answers
SOURCE: Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Posted on Nov 03, 2010
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
How do I turn on the FWD/DND button?
It depends on what phone system the 7130 is connected to. Most FWD sequences start in the 7xx's. In a TA series, you have 711 ext # to forward it to some extension and 714# for DND. On a TD it's 710x with 2 being all calls and 7101 being DND. . If you have your 7130 connected to anything lower (like a flat pack 308,616 or 1232) just look at the button because I don't think it will do anything else :-)
In the above examples, ending in 0 usually cancels, like 7100 cancels CF and DND on a TD and 710# on a TA. The OM or user's guides to your particular KSU will have the details under Call Forward and Do Not Disturb.
Carl
Jan 21, 2011 | Panasonic KX-T7130 Corded Phone
Carl
Nov 03, 2010 | Panasonic KX-T7730 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Calls go directly to voicemail
You have a FWD/DND button on the top of the phone. Press it and read your display. One of the choices is FWD with a destination displayed, one is DND, and one is Fwd/DND Off :-)
If you don't have DND set, it will only toggle 2 actions.
You can change the time/destination by using the *7104 xxx # where xxx is the voice mail system. 7104 is the CF No answer code (5 being busy/no answer and 2 being all calls and 3 is busy alone). *7100 clears it all.
In case you wonder what happened to *7101...it's Do Not Disturb.
Carl
Sep 24, 2008 | Panasonic KX-T7630 Corded Phone
Jun 06, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic Lot Of 10 Hac Vb-44223a-g Dbs 22-key Lcd Speaker Phone Telephone Logo
62 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
