I have a G.E. tpo loading washer .the aggitater is not working. it spins freely by hand. i cant see how to get it out. i took the top cap off .there is no nut to take off. there is a top and bottom half.i dont know how to get them off.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
SOURCE: Maytag Performa Large Capacity Top-load Washer
Krazytech, Just because your solution didn't work for me does not mean it won't be helpful to someone else who reads it. It was just not helpful to ME...but thanks for the personal attack. You may be a "Master" at technical questions, but you fail miserbly at customer relations. By the way, some people need help with THEIR spelling before posting THEIR negative replies.
Posted on Sep 17, 2007
BADBOYJAY
  • 264 Answers
SOURCE: Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Posted on Jan 07, 2008
vest6
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
ngfam1
  • 639 Answers
SOURCE: Maytag MAV6200AWW top load washer,will
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 4 Answers
SOURCE: the agitator on my kitchen aid kawe577bwh1 used to
You need agitator dogs. Part # 80040 around $7
Posted on Nov 21, 2009
How to remove the top part of the agitator of a roper model ras8445kq0
Often agitator tops do spin somewhat freely, for safety reasons. Most of the work gets done at the bottom, anyway. Unless your clothes are getting tied in knots, I wouldn't worry about it.
But if you want to look, they're usually not that hard to remove. I can't picture yours off the top of my head, but look for a cap/cover/cup on top that can be removed by hand, and there might be a bolt underneath that. There's usually a lot of friction in addition to the bolt holding it in place, so you might use an old towel slipped under the agitator and cinched to give you more leverage/grip.
Good luck.
Jun 12, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
Should the pump motor spin freely
You should be able to move it easily by hand.  If you cant, something is probably stuck in it.
Dec 19, 2009 | GE Profile WPRE6100G Top Load Washer
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not engaging
it will spin freely try to move it back and forth in full spins. if it spins both ways you need to replace the agitator dogs
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is not agitating but goes through cycle. agitator spins both ways freely and not one way as it should? How do you get the agitator out?
remove cap or dispencer,,,pull the plastic cover up with you hand,,,now you need a 1/2 inch wrectet,,,remove bolt holding auger (top agitator) then pull up agitator..onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
