Sound coming from TV speakers seems muffled because TV is in an enclosed shelf unit area. Would like to connect external speakers to eliminate the problem.
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
