Question about Brother HL 1250 Laser Printer
Replace cartidge How do you replace the cartridge to this printer?
    President:
  • 8,637 Answers
Go to this site and download the manual.
http://www.manualnguide.com/download/manual-guide/brother-hl-1250-printer-users-manual.html
On page 59 & 60 shows how to remove and replace the ink cartridge.
Hope this helps. Bud
Posted on Jan 22, 2009
  • 286 Answers
SOURCE: Pixma iP4200
You either have bought a bad cartridge, or are using a generic or refilled cartridge, or have damaged the contacts in the carriage assembly.
Replace the same cartridge again only make sure you use a new Canon cartridge. If this does not help, either the contacts in the carriage assembly are bad or the main board has bit the dust.
Repairing the contacts would require you to remove the upper case so you can access the contacts, remove the ink cartridge and streighten out the contacts before reinstallig the cartridge.
The contacts are located at the front of the carriage assembly under the ink cartridge.
Posted on Dec 30, 2007
v4ndre
  • 148 Answers
SOURCE: Printer won't recognize cartidges
try to use the SSC epson reseter...
this should fix your Printer!
Good Luck!
Here´s the link: www.ssclg.com/epsone.shtml
Posted on Dec 05, 2008
SOURCE: Squeaky Printer
Mine had a similar squeak and I took the toner out and shook it. Squeak went away.
Posted on Apr 29, 2009
APremkumar
  • 564 Answers
SOURCE: Replacing the ink cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 26, 2009
freetek
  • 5568 Answers
SOURCE: I treid to replace the ink cartridges on my
After several attempts to get a Lexmark printing again, I tried using household ammonia as a soak for the printhead of the catridge. I once serviced printers of all kinds and most of the integrated cartridge/printhead types responded well to window cleaner and blotting with a lint-free paper towel but the Lexmark only got partially clean doing this. The ammonia solution did the trick in only about a half-hour of exposure and subsequent blotting showed good ink flow.
Yeah, it stinks and it is better to cover the container you use with an inverted bowl so you don't choke.
Posted on Oct 14, 2009
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
It says check print cartridge
first of all turn off the printer ... remove the cartidge.... try to clean the slots where the cartidges gets installed as well you will find dotted bronze spots on the cartidges try to clean it... turn on the printer and inser the cartidge... if u still get the error the msg for both the cartidge try putting in a new cartidge id you can and if still there is the messag if might be th problem with printer.... replace the printer....
Apr 30, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer does not recognize Black cartridge. How do correct it? Clean it? This is the 3 or 4th replacement cartridge. The color cartridge light goes on, the black does not light up at all .
the black cartidge slot has gone bad and u wuld have to replace the printer ... coz the copper strips/dotted lines which u see on the ink cartidges, you wuld find similar thing inside the slot ... that acts as an sensor .... its gone bad.... sorry
Apr 14, 2010 | HP D4360 DeskJet Printer InkJet
Dell 924 all in one printer cannot remove low ink warning
This happens if you are not using the Dell ink Cartiridges. However there are few work arounds on this issue.
Firstly, Please try to remove cartridges and then clean cartridge slots and make sure that printer is OFF and completed disconnected from Computer. Remove the cable between Printer and Computer while you do this.
After that restart the computer and then try to reconnect every thing and check if this happens
if else, then open the printer properties or printing preferences and locate the option that says Calibrate the cartidges. and do the calibration of cartidges. Calibration is compulsory once if you replace the ink cartidges.
if still fails then reinstall printer software. This should resolve the issue.
Thank you.
Dec 31, 2008 | Dell 924 All-in-One InkJet Printer
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
Replace ink cartidge
Here is a link to the Setup Guide. Go to Step 5 for instructions for ink cartridge installation.
J5780 Setup Guide
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
Ink cartridges
GO TO EPSONAMERICA.COM SUPPORT AND TROUBLESHOOTING PAGE.FIND YOUR MODEL NUMBER.SELECT USER GUIDES.YOU WILL FIND A SECTION ON HOW TO REPLACE THE CARTIDGES FOR THE PRINTER.
Aug 25, 2008 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printhead ink cartidge replacement
Ok, you may have blocked printheads. Remove cartridges, using a cleaning solution and cotton buds (q-tips) thoroughly clean all residue. Now replace cartridges and try again.
Aug 15, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Brother HL 1250 Laser Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
