Question about Kirby Ultimate G Bagged Upright Vacuum
Can I use an off brand cleaner in my kirby shampooer
I am out of the Kirby brand liquid carpet cleaner. Will I get the same results if I use a different brand cleaner? We are having a blizzard out side and I can't get to the Kirby store.
Yes, I do all the time. I use a very concentrated organic cleaner from Amway so it doesn't take alot, and works great! I would just be careful as to how much cleaner you use.
Posted on Jan 10, 2009
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
Tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby G4 Bagged Upright Vacuum
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g2000 shampooer
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Here is the instruction guide for the shampooer also. Hope this helps...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 10, 2009 | Kirby G6 Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
467 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
