Question about EPO Technology (CR-856E) Internal 56x CD-ROM Drive
CD ROM doesn't detect discs at all?
I recently installed this model of CD ROM drive on a work computer running Windows 2K. It was one I'd had from a previous computer and works fine in other systems. The computer detected the drive fine, and for about a week it had no trouble detecting discs. Then, at seemingly random, it stopped detecting the discs. When I put a disc in, the drive will light up for a few seconds as if it's reading the CD, then it stops, and doesn't show that a disc is loaded. I have disconnected and reconnected the cables, replaced the IDE cables, triple checked the jumper configurations and bios settings, everything should be working flawlessly, but it isn't. I even had a tech talk me through resetting everything in windows to make it redetect the drive, to no avail.
  • Andrew Laine Jun 07, 2007
    I should probably mention I've swapped the drive out to another system, and it works fine there, so the drive is definitely not dead. If the Bios was a problem, why did it work fine for the first couple of weeks?
  • 23 Answers
My best quess wouldbe that the drive went out and you just don't realize or want to admit it. Switch it back to another system to test it, if it still dosn't work scrap it. Otherwise I would try booting to dos with an old 98se disk, see if it's your OS if it is, reinstall 2k.
Posted on Jun 06, 2007
  • Nathan Bass
    Nathan Bass Jun 06, 2007
    I almost forgot. It could be that bios all together, sometimes, though rare you will find certain drives that just plain wont work with certain bios's... Good luck
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
How do i fix my laptop when it says no hard disc is found
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 02, 2012 | Toshiba Computers & Internet
Dell dvd bad CD OK
please check what type of dive it is cdrw/dvdr or only COD -rom...if only cd rom it will not read DVD's...go to run ...then type msinfo32 then components finally under check the type of CD/DVD drive installed...if everything is ok...reinstall the chipset drivers....thanks...also if u can check in BIOS if the drive is getting detected.
Feb 13, 2012 | Computers & Internet
Monitor to other cpu and it works fine. Tried recovery tools and rcovery disc but receive errors, boot from cd rom no emulation, and no hard drive found. Help!!!!
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 19, 2012 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
I cannot open cd's on my emachine 4260. Can you help? The discs have data on them (Knitting patterns)
It could be a proiblem with the cd-rom drive or the computer. You can try and run a cd lens cleaning kit in the drive to try and clean the lens. Also try using a different SATA or ATA cable for the drive depending on which one it has(the cable could be bad). I would take out the cd-rom drive and try installing it into another computer to verify if the drive is working. If the drive acts the same in a different computer then replace the drive. If it does not then there might be a hardware problem with the e-machine motherboard.
Nov 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
Plans For Online Storage And Online Backup - Dataalign Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
See all EPO Technology (CR-856E) Internal 56x CD-ROM Drive Questions
EPO Technology (CR-856E) Internal 56x CD-ROM Drive Logo
259 people viewed this question
Top EPO Technology Computers & Internet Experts
David Payne
David Payne
Are you an EPO Technology Computer and Internet Expert? Answer questions, earn points and help others
