Question about Contex Nextimage Scanner Operating Software
Nextimage has started to automatically crop image
We upgraded our software right before Thanksgiving. Everything worked fine. However now nextimage has started to cut off part of the image, almost half. Please help! A lot of scanning gets done around the holidays. It is a 4200 series large format scanner.
How do I get my hp f4280 to scan to my comp.
Hello Lulu !
To use the scan features, the HP All-in-One and computer must be connected and turned
on. The HP Photosmart Software must also be installed and running on your computer
prior to scanning. To verify that the HP Photosmart Software is running on a indowscan
computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower
right side of the screen, near the time.
To scan to a computer
1.
Load your original print side down on the right front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it. Any
edits that you make apply to the current scan session only.
The HP Photosmart Software has many tools that you can use to edit your scanned
image. You can improve the overall image quality by adjusting the brightness,
sharpness, color tone, or saturation. You can also crop, rotate, or resize the image.
3. Make any edits to the preview image, and then click Accept when you are finished.
Heres a link you will find everything you need to know about the f4280 (scan features starts on page 63) :
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jul 15, 2010 | HP DeskJet F4280 All In One Printer InkJet
Tip
Thanksgiving Day Wallpaper Collection For Your iPad
Are you ready for Thanksgiving and all that tasty food? While you wait for the holiday to arrive we have a larger than normal set of wallpapers to help set the mood on your iPad.<br /> <br /> Note: Click on the picture to see the full-size image-these wallpapers vary in size so you may need to crop, stretch, or place them on a colored background in order to best match them to your screen's resolution.<br /> <br /> thanksgiving-day-01<br /><img src="1.jpg" /> thanksgiving-day-02<br /><img src="2.jpg" /> thanksgiving-day-03<br /> <img src="3.jpg" /> thanksgiving-day-04<br /><img src="4.jpg" /> thanksgiving-day-05<br /><img src="5.jpg" /> <br />For more Wallpaper visit <a href="http://www.ipad-converter-mac.net/ipad-resource/ipad-wallpapers.html">iPad Wallpapers</a>!
on Nov 24, 2010 | Computers & Internet
Asure ID Express hangs up in image editing mode, before printing.
The problem turned out to reside in the software itself. The company was aware of it and promptly provided a fix.
Sep 01, 2009 | Synercard Asure ID Express
Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
The print shop is not cropping correctly. Once I have the image I want to crop ready and click on applty crop the image crops another area such as the feet of a person.
You have to choose area effects tab first, click on the area (aprox) where you are going to crop, then choose crop and orientation tab and do your croping. I don't know why it works like this, but this has solved the problem for me.
Jul 12, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Crop the photo in diffeent shaps like heart.
The crop tool will not let you crop in shapes like elements cookie cutter tool will. However, there is a work around to do what you want to do which indecently is the same as you would have to do in Photoshop CS4.
1. Create a new document file or press Ctrl + N.
2. Open an image you want to crop.
3. Press Ctrl + A then Ctrl + C to copy the image.
4. Select the new document file you created and press Ctrl + V to paste the new image in a new layer.
5. Select the Rectangle tool or press U for the hotkey.
6. Move the mouse over to the Rectangle Tool and hold down the left mouse button and select Custom Shape Tool.
7. At the top of the menu you will see a Shape: icon with a pull down option. Left Click on the arrow to expand the window to select the shape you want. If you want more shapes to choose from when the shape window is displayed click on the arrowhead with a circle around it and select a new library or all.
8. Use the mouse to draw the shape to the size and location you desire.
9. The shape will be in a new layer with a mask which will cover the image. Hold down the Ctrl key and left click on the Shape 1 layer in the layer window. This will mask the shape and only the shape.
10. Press Ctrl +Shift + I to invert the mask selection.
11. Use the Select pull down menu to Feather, Modify, Contract, Expand and Border if you want apply those effects around the edge of the mask.
12. In the Layer window click on the eye next to the Shape 1 layer to hide the image.
13. Select the image layer you want to crop and press delete which will delete everything outside the custom shape you created.
14. Do not forget you can right click on the image layer and select Blending Option to add drop shadows and other special effects for the cropped shape.
Jun 05, 2009 | Adobe Photoshop 7.0 for PC
Command Action
Open - Window - Action. Click on arrow on top right. Create New Action name it, and record an action by cropping one of the images.
Go to File - Automate - Batch. And choose folder with images you want to crop.
Apr 05, 2009 | Adobe Photoshop 7.0 for PC
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
Indesign Crop Mark and nudge
To crop or straighten images in Camera Raw
In the Camera Raw dialog box, select the Crop tool or Straighten tool .
(Optional) If you want the crop area constrained to specific proportions, click the Crop tool icon and choose a proportion from the pop‑up menu. Choosing Custom opens the Custom Crop dialog box, where you can specify the proportions or the dimensions of the crop. Click OK.
Do one of the following:
To crop the image, drag the Crop tool over the image.
To straighten the image, drag the Straighten tool in the preview image to establish what’s horizontal or vertical.
(Optional) To adjust the crop area, do one of the following:
To scale or rotate the crop area, drag just outside the bounding box handles.
To move the crop area, click in the bounding box and drag.
If you selected several images in the Camera Raw dialog box, they are all cropped to the same size, with the crop applied in the same position.
Note: To cancel the crop operation, press Esc with the Crop tool selected or click the Crop tool and choose Clear Crop from the pop‑up menu. To cancel the crop and close the Camera Raw dialog box without processing the camera raw image file, click the Cancel button or deselect the Crop tool and press Esc.
Click Open, Done, or Save to apply the crop and process the camera raw image file.
Oct 20, 2007 | Adobe InDesign CS2 for PC
Scanning
Reinstall the the software Come back it that does not work
Mar 22, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Contex Nextimage Scanner Operating Software Logo
37 people viewed this question
Top Contex Office Equipment & Supplies Experts
k24674
Are you a Contex Office Equipment and Supply Expert? Answer questions, earn points and help others
