Question about Intel (SL5TL) Pentium 4, 2 GHz Processor
My system doesnt start
I have got a INtel celeron CPU...it was working good..Sudenly one day i switched on..I see the cpu fan spinning ..but nothing appears in screen..I am sure that there is no prob with HDD and RAM..What would be the problem?
  • 3 more comments
  • nematics
    nematics Jan 10, 2009
    Ya..I am sure that monitor works good. I tried with anothe rmonitor, but nothing displays. I think there must be some problem with the board..but donno which part of it..eiither smps or some cpu component..
  • nematics
    nematics Jan 11, 2009
    the Mboard has got a onboard video card. I havent tried fixing another video card yet. Will let you know the result as soon as i test so. But another question that I have is, even though the video is faulty, while boothing up, the cpu will give a beep sound isnt. I dint hear that sound which made me assume that the system isnt booting..any ideas due to this?
  • Bill Speer
    Bill Speer May 11, 2010
    A single beep that you haven't heard before? I'm guessing that the system is giving you an error message or warning that obviously can't be seen due to the video issue. Does it sound like it continues to load after that? Do you have to hit Enter to get it to keep going or can you even tell if there is any activity after that?
  • Bill Speer
    Since you know the computer is starting up and another working monitor doesn't work either, we can assume the video capabilities are bad. If you haven't installed a separate video card, most likely the onboard video is bad. I am assuming it's not a high end PC that came with a separate graphics card. If a friend has a video card laying around, you can plug that into a slot on the motherboard to give it a try. You can tell if you have onboard video because your monitor will plug into the same area as your ethernet cord, USB ports, and mouse and keyboard. Video cards are in an area farther away where those removable metal tabs are for expansion cards. There are some low end video cards that are available for less than $30 and I've even found a few for around $15. Definitely not for high end gaming but perfect for the web and applications.
    Let me know what comes from this info.
  • Bill Speer
    Do you have a second monitor you can switch out? Have you checked the monitor itself to make sure it's not set for digital vs. analog (or vice-versa)? Are all cables and plugs tight and secure? Let me know what you come up with and we'll take it from there.
  • 40 Answers
If no beeps (remove the RAM and for sure has to beep if the motherboard is OK) at all and no video signal you may look to:
1. a new PS - power supply or
2. a new CPU or
3. a new motherboard.
Posted on Jan 13, 2009
All fans spin very fast. no boot / no display
you could try to check the bios . you would need to open the laptop to see the bio reset pin . if this doesnt work . more thank likely it could be a faulty CPU
Nov 11, 2013 | Intel Corporation Network Servers...
My cpu opens but the monitor doesnt starts
Hi Chiver, there could be possible several reasons, such as RAM into CPU or VGA means Graphic Card issue and consequently there is one more possibility with Monitor. Sometimes due to moisture monitor does not show display and in this case you need to keep monitor in the sunshine for hour almost and then it will work perfect.
Good Luck
Feb 03, 2013 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Intel Celeron Cpu 430 1.80ghz Driver Download
hello, there is no driver downloads for intel celerons...if your computer will not work with this cpu, you would have to do some searching on your computer manufacture to see what cpu is supported.
thank you
Sep 10, 2012 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
No startup power
if a computer will not boot at all it is either the ram memory to blame ..and in this case it will start the fan but fail the boot and either make a beep or will restart and make a click noise...in a loop ..The action is to remove the ram and place back and see if it works with one module at the time ..This way you identify the wrong one ..
Another issue may be the CPU fan ..If it not starts..the computer will not work ..cause it is shut down due to overheating the CPU in seconds ..check the fan to work ..and to be plugged on the motherboard..if it seam not working change it ..
It may be a CPU failure..in this case it starts but nothing on screen but the fan spinning ..and makes no noise and do not let you do anything ..
If it does start ..and only shows a few devices but never boot up ..it may be the hard disk ..and in this case will tell you it failed to boot cause the hard disk is not functional ..or it will say it failed due to missing operation system ..
good luck ...the problem need to be taken one step at the time ..and eliminate causes...If you have another desktop and the devices match ..try them one by one ..and see what is working and what not ..
Dec 17, 2011 | Mirus Intel Celeron D 360 512MB RAM 80GB...
I have a Compaq Presario PC, SR5210NX Processor with Intel Celeron Processor 420. I got a message that windows did not start correctly and it said to run the diagnostic, which I did. After that was done,...
Unplug power and Open the computer case. Vacuum all the dust
inside it. Visually inspect all the fans: Power Supply, CPU, Chipset
and Case...Make sure they are spinning easily and freely.
Plug the power in, and turn on your system. Watch the fans, especially
the CPU Fan and the Main Board Fan (System Fan). Oil and dust over
times may accumulate and prevent the fans from spinning properly.
If you are handy, you can remove them, give them a good wash and lubricate
the shafts with a few drops of WD-40, they will be as good as new again.
Fans don't go bad that easily.
Jul 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
L20 197 model (celeron) laptop.
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Oct 04, 2009 | Computers & Internet
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Cpu fan heatsink spinning at abnormal top speed
I'd change the fan. It could be the thermostat is acting up.
Jun 11, 2008 | Intel D101GGC Motherboard
Intel (SL5TL) Pentium 4, 2 GHz Processor Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
