Question about Hotpoint Aquarius WF000 Front Load Washer
The control panel lights run up and down in sequence and dosnt seem to have rinsed or span properly
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Nov 28, 2012
Can't select cycle and won't start.
you didn't mention the model number , but I can tell you some models wont start if there's no rinse agent in the dispenser , also for stuck controls a trick that works is to find the breaker for washer in your power panel and click it off for one minute then back on this will force a reset of controls
Jan 22, 2016 | Dishwashers
Quick rinse light blinking
Quick Rinse light blinking is usually a short in the control panel membrane. Replace the control panel (The outer part, not the control board inside)
Aug 26, 2014 | Kenmore Dishwashers
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
Eb20b heater temp goes down from 120 degrees to 90. 240v at sequencer and both heating elements and limit switches, testing from ground to wiring on those. when i take cover off of fan motor enclosure...
Sounds like an airflow restriction. If you remove cover you are giving the fan all the possible air it can get, therefore it seems to run properly.
Jul 08, 2017 | Coleman Heating & Cooling
Whirlpool dishwasher Clean light is flashing, we just bought it last week and after the third wash, the Clean light started flashing and it won't go off, which stops it from doing anything else. User manul...
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
I hope this helps you solve your problem.
Dec 29, 2009 | Dishwashers
Control panel light on dryer wont go off
The front touch panel will need replacing is the touch buttons fail to initiate a sequence.
The panels cost about $200.00. You can do it yourself.
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
