Can anyone help with this asatom 2.1 Bluetooth adapter doesn't seem to want so power up
Can some one fix it
Posted on Aug 19, 2013
How to turn on bluetooth on acer aspire one zg5 laptop
When I saw the specification http://gdgt.com/acer/aspire/one/zg5/specs/
I noticed that your laptop doesn't have a build in bluetooth device. You must buy a USB bluetooth device from somewhere. For example
http://www.bestbuy.com/site/Rocketfish%26%23153%3B+-+Micro+Bluetooth+USB+Adapter/8820886.p?skuId=8820886&st=bluetooth%20dongle&lp=1&cp=1&id=1207351932175
or if you find cheaper.
Good Luck.
Jul 13, 2012 | Acer ASPIRE ONE ZG5 COMPATIBLE LAPTOP LCD...
X7170 not powering up
Try this approach:
1. Remove the power adapter from the printer. The power adapter is the black box where the power cord is plugged in at the back of the printer.2. Disconnect the power cord from the power source.3. Reconnect the power cord directly to the power outlet in the wall. Bypass any surge devices or power outlets.4. Re-plug the power adapter into the printer.5. If the printer won't automatically power on, press the power button on the printer operator panel.
I hope this helps.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Nov 28, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
Want to pair Pro 705 via Bluetooth with Nokia E72. Cell asks for passcode. Have tried 0000 and 1234. Doesn't work
1 Insert a Bluetooth USB adapter into the USB port.
Bluetooth Dongle Connected appears on the display.
Note: A Bluetooth adapter is not included with the printer.
2 From the printer control panel, press Setup.
3 Press the up or down arrow button to scroll to Bluetooth Setup, and then press OK.
4 Press the up or down arrow button to scroll to Security Level, and then press OK.
5 Press the up or down arrow button to select the security level, and then press OK.
• Select Low to allow Bluetooth devices to connect and send print jobs to your printer without requiring users to enter a pass key.
• Select High to require users to enter a four-digit numeric pass key on the Bluetooth device before connecting and sending print jobs to the printer.
6 The Bluetooth Pass Key menu opens on the operator panel display if you set the security level to High. Use the keypad to enter your four-digit pass key, and then press OK.
May 07, 2011 | Lexmark Prevail Pro705 Small Business...
CAN I CONNECT A THIS TO A LAPTOP? IF I CAN HOW?
You can use the Plantronics Explorer 240 on your computer if your computer has Bluetooth built in. Just turn on the Bluetooth feature in the computer and pair up the headset. You can get a USB Bluetooth adapter if your pc doesn't have Bluetooth built in, then just pair the headset to the adapter. Here is a link for the 230 / 240 user guide, it will have the pairing instructions for the Explorer 240.
Plantronics Explorer User's Guide
Good luck from Headsets Direct!
Mar 17, 2011 | Plantronics Explorer 240 Bluetooth Headset
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
I cannot seem to connect my phone to the bluetooth feature. Yes, my phone is bluetooth capable.
Hello mystcbsct,
I'm assuming that you have the BCE-400 optional Bluetooth adapter or similar third-party adapter installed.
The initial setting is BT OFF. Go into setup by pressing F/SETUP for at least 2 seconds to activate setup mode. Use the volume control (called rotary encoder in the manual) to select BLUETOOTH IN and press ENT. Press and hold F/SETUP again to exit setup mode.
Hope this helps.
Oct 19, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
I am trying to setup my bluetooth headphones and they did not come with instructions. I just need to know how to put them into discovery mode.
I bought one myself, I have a Vista OS, non-integrated bluetooth laptop.. I had to pop in the USB dongle for capabilities....Still cant get the Mic to work though...so if anyone knows anything on that....I went to HP live chat session too.
BUT HERES THE MODES YOU MAY NEED TO PUT IT IN...
Searchable/Discovery- Hold down the power button about 6-7 secs and it will sound a few short low beeps and flash between Red and Blue, then search 8)
Erase Pairing Profiles- Press and hold the Track forward/track backward Button together until it flashes purple.
Hardware reset- if headset is screwy, froze up, LED display is incorrect...Plug in headset, and hold down bothh Volume buttons, this will power it down and reset its state of confusion, lol
Passkey is always '0000' by default
2-short Hi beeps....Connected
2- short low beeps....pairing mode also
1 long Hi beep.....Power On/Off
1 long low beep....lost Connection
Hope that helps... merry christmas
Dec 03, 2008 | Insignia Bluetooth Wireless Headphones...
Bluetooth problem
Go to control panel and look for My Bluetooth Devices and double click it and click search for new devices, only then will you be able to set it up.
Jan 22, 2007 | Nokia Mini USB Bluetooth Dongle w/...
130 people viewed this question
 Grubhead
Grubhead
