Question about LG Washing Machines
My LG WM 1832 CW washing machine does not spin LE code appears, water and clothes in machine how do I open the door?
Washng machine do not spin, code LE appears, water and clothes in machine. I need to get machine working again
    Top Expert:
  • LG Master
  • 9,472 Answers
Take a look at this page.
Posted on Nov 28, 2012
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Posted on Apr 19, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
LG washer WM 2277HW Wont spin LE on control panel
LG error codes:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
LG washer notes:
Problem:
An occasional LE error but always a slow or no spin.
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
Your service manual and more LG washer notes HERE
Mar 07, 2011 | LG WM-2277HW Front Load Washer
Washer does not spin and displays an LE error
LE is lock error..This most commonly means that the interlock is faulty...This is component which stops the door from opening during wash, and allows power to the machine when the door is shut..Replacement probably needed..Not a big job...Good luck....Nomess
May 22, 2010 | LG WM-2277HW Front Load Washer
LG WM-1832 C
the spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
May 28, 2009 | LG WM-1832C Front Load Washer
Apr 19, 2009 | LG WM-1832C Front Load Washer
How do I make my WM 1832 CW washer ready to move?
It is best to re-install the four shipping bolts in the back of the machine during the move. If you don't have them, contact a dealer. Please don't rate, as anything but a Fix-Ya lowers my score. Thanks.
Jan 26, 2009 | LG WM-1832C Front Load Washer
How do I make my washer ready for moving? I have an WM 1832 CW
you should ( ifyou have, reinstalla the origianl shipping brackets) thiswill preventthe machine from bouncingaround internally
LG front load machine with LE code and no spin
LE is a locked motor error. Not to worry as 95% of the time this is just a bad hall sensor (motor position sensor). It is very easy for a technician to replace and the cost is very small.
Hope this helps, please rate my solution.
Oct 25, 2008 | LG WM-2077C Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
141 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
