When driving can't get acceleration over 20km/h
LOSS OF ACCELERATION It
can be fuel pressure issue or it's the problem with accelerator pedal or its
clogged filters causing there. There
are many other possibilities. I suggest you to go through the list of help
links mentioned below, these will help you to confirm where the actual fault
lies: ------- ----------- http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html --------- http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html -------- http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html -------------
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html -------- http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html --------- http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html --------- http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html -------- http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html --------- http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html -------- http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html ------------- These details will help. Thanks.
Jerks and Hesitates During Acceleration?
http://technoanswers.blogspot.in/2012/07/2004-dodge-town-country-jerks-and.html
Loss of acceleration?
Headlights flickering and car
hesitates to start?
How exactly the Vehicles
Accelerator Cable works?
How exactly Vehicles
Accelerator Pump Diaphragm Works?
2000 Toyota
Avalon: Engine Lean Codes and Knock Sound on Acceleration?
2004 Toyota Avensis:
Acceleration And Deceleration makes noise on Front End?
Wheel hop under hard acceleration?
2009 Chevy impala accelerator pedal sensor?
Nissan Pathfinder stalls and bucks on
Acceleration?
Acceleration lag problem?
SOURCE: My '98 BMWis jerks and backfires after 20km's or so.
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully electronically
controlled by a computer called the PCM and TCM (Power Train Control
Module, Transmission Control Module). When a problem like this or
other drive-ability related problems occurs the computer stores a
record of the problem (there are of course some exceptions to this,
like the fuel pump, engine coolant temperature sensor and MAF sensor
for instance) in the form of a fault code in its memory, to read
these fault codes you must have the systems memory scanned with a
special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED
THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT
MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for
correct spec for your make and engine type.
truck will not go over 20km/h
