How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
My LG front end WM 1832 CW washing machine is lock with water and clothes inside, the motor is not spinning, LE code appears I want to open the washing machine
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Posted on Nov 28, 2012
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Posted on Apr 19, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
Can the lg washers wm 1832 cw handle a twin sized comforter?
It depends on the thickness,content and weight of the comforter.
If you have to stuff it in, don't wash it in your machine..take it to a laundromat.
Or if it is down filled, take it to a dry cleaner.
If it is a cotton filled quilt it will get very heavy when wet and may damage your machine, so I would take one of those to the laundromat as well.
If it is a light weight polyester-filled comforter, twin size and fits easily in your machine with out stuffing it in, it is probably okay.
Dec 20, 2010 | LG Washing Machines
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
LG WM-1832 C
the spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
May 28, 2009 | LG WM-1832C Front Load Washer
Apr 19, 2009 | LG WM-1832C Front Load Washer
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
How do I make my WM 1832 CW washer ready to move?
It is best to re-install the four shipping bolts in the back of the machine during the move. If you don't have them, contact a dealer. Please don't rate, as anything but a Fix-Ya lowers my score. Thanks.
Jan 26, 2009 | LG WM-1832C Front Load Washer
How do I make my washer ready for moving? I have an WM 1832 CW
you should ( ifyou have, reinstalla the origianl shipping brackets) thiswill preventthe machine from bouncingaround internally
I have a LG washing machine, model WM2277H. Ready to wash clothes, put the machine on but no water is entering the machine. water valve is open, cleaning the filter inside the hot and cold tubing to the...
Kinked inlet hose. Screened hose washer in inlet hose plugged. Frozen water supply pipe(s). No power to washer inlet valve(s). Old inlet hoses with separated layers, blocking water flow under pressure.
Turn off valves, remove from machine end, put in bucket and turn on valves to make sure you have water up to machine. Now work back to find why you are not getting water into machine.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
