Question about Karcher 1750 psi Electric Pressure Washer
No pressure water runs through, no pressure
  • Anonymous May 09, 2009
    I have a honda husky 2600psi power washer and receiving no pressure to the gun or wand.The motor seems to run fine but no water is coming through. Have noticed that there is water coming out of a small black valve at the rear bottom of the machine.
  • David Ford
    David Ford May 11, 2010
    If I understand this correctly, you have water flow but no pressure. I have to ask is the motor on? If so I would have to think that one or all of the valves are stuck, but possibly it could the unloader. Was the tool run without water at some time? Also was it allowed to idle without being used. Let me know and I would need the complete model and brand to see what I can find.
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
How do i connect water pipe to the pressure washer
Not sure exactly what the question is however, many people wonder if there is another way to connect the pressure washer to water. On occasion there is a need to use the pressure washer where there is no water faucet/ supply. You can use a large container of water to supply the pressure washer. It does not need to be under pressure. Just try to get the air out of the supply line then use as normal being carefull not to run out of water (shut down before you run dry).
Oct 22, 2011 | Garden
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
I have a pressure washer that runs but no pressure, I was using it at the time and all of a sudden no more pressure.
when running your pressure washer, if your running it at home make sure other appliances are not running also like a dishwasher or washing machine. when their pulling water it decreases the volume of water going to your pressure washer. if this is not the case. check the inlet from the water hose to the pressure washer, make sure the filter is clean. also the tips on the wand, make sure there is no hardwater build up. good luck!
Nov 22, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Jul 09, 2010 | Karcher G3025OH Pressure Washer
Hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Apr 04, 2010 | Briggs Stratton 020273 Elite Series...
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Pressure washer has no pressure coming out
I think yor hot water softened one of the pressure seals and has allowed it to buccle. This will drop the pressure away from the pump. It will require new seals to be fitted and the cost is close to $200.
Aug 14, 2009 | Garden
Karcher 1750 psi Electric Pressure Washer Logo
212 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
