Aiwa NSX-S909 volume nob problems - Audio Players & Recorders
techman
  • 3130 Answers
SOURCE: volume knob
In other words the lever that the front knob is attached to is broken or the microswitch is bad or broken.. if your not a tech please take the unit in to a shop as there are no user serviceable parts inside these units. Good Luck
Posted on Aug 03, 2006
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
  • 7 Answers
SOURCE: AIWA shelf system volume button
hi there if u want fix volume botton,u need open total aiwa set,but very hard job need a bit pasion,it was happned to me too!>Wht u gona doo u need open central part where screen connected there aiwa wolume boton system,u need open that all,befreo u need take it out botton control plastic front set,but be gentely because if bottons fall down u can put them back then same pose,So u need the volume panel open,u will see small controler siting on the micro chip i can take it that out from panel of volume,then clean it tootbarash,Possible can be dirty or oily.i did also that same clean and put everything same back,it cost me 5 our fix that alll,hope will help!
Posted on Oct 09, 2012
Volume nob wont work
The contacts on the volume encoder are dirty. The only fix for it is to take it off of the board, open it up and clean the contacts. You need to be pretty handy with electronics in order to pull this off. I don't think you can find a replacement encoder any more. Sony bought Aiwa years ago, but doesn't really support the product with parts anymore.
Dec 22, 2012 | Aiwa NSX-AJ200 Shelf System
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
How can I play my ipod on an Aiwa NSX-AJ310?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX. It'll be advisable to lower your volume, so that you may not cause any damage to your speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
JaHa
Nov 30, 2009 | Aiwa NSX-AJ310 Shelf System
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Dec 15, 2008 | Aiwa NSX-DS55 CD Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
 Grubhead
Grubhead
