There
are many possibilities that can cause car to make noise. It's
actually from where the noise is coming from. Front end or rear end. From
engine area or from inside the steering or from brakes. There
is N-number of possibilities for the car to make whining noise or any other kind
of noise. --------- For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------ Click
the link below: ----- Car makes clicking noise? http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html -------------- Car makes whining noise like
driving on rough pavement? http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html ------------ Chirping Noise From Car? http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html ---------------- What are the possibilities for
Clicking noise in car? http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html -------------- Squealing at start up on car? http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html -------------- Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html ----------- Vehicle making Clunk Thump Thud
noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html ------------ 4X4 Truck makes roaring noise in
the front end? http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html -------------- Heater makes clicking noise under
dash on Ford Explorer? http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html --------------- Clicking noise under dash and
front defroster not working? http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html ------------------ Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html --------------- Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html ----------------- Car Alternator Bearing Makes
Grinding noise? http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html ---------------- Engine makes noise and Cooling Fan
belt Breaks? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html -------------- Vehicle Makes Clicking Sound While
Taking turns? http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html ------------- ABS light comes on and Car makes
Grinding noise? http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html ----------- These will help. Thanks.
SOURCE: Driver side power window stops working in 2003 mits. eclipse
the switches need cleaning ,they have contacts in them that get dirty you can spray contact cleaner on them or use emery paper to file them, they are not to hard to pull apart
SOURCE: radio code Eclipse Spyder,how do you enter
Contact your local Dealership and ask for Parts. They have all the Codes and can tell you by Running your VIN Number.
SOURCE: Changing the front speaker 2001 Eclipse Spyder
There are 7 screws all together to remove the door pannel. First, you have to take off the hanlde for the door. the 2 plastic covers on the handle pop off revealing 2 screws on the top and bottom, remove those. then behind the the door handle on the inside, pull it as if you were to open it and there is a screw that you have to remove. Then there are 2 screws on either side of the door pannel, both are farily close to the top, remove those, and then its just a matter of popping the pannel off. start from the bottom, pop it off then slide it up. becarefull, after the door panel is free, there is a connection for the power doors and windows unhook that then the pannel will be free. after that the speaker will be right there and its common sense on removing that. good luck.
SOURCE: WHICH ANTIFREEZE SHOULD I USE ON MY ECLIPSE SPYDER
When choosing antifreeze don't be mislead by the color! In fact,
unless you open the bottle and pour some out you won't know what color
you are getting in the first place. What to look for is the information
on the label.
Typically the "Red" antifreeze is extended life
150,000 mile (5Yr) antifreeze. While the "Green" solution has been the good ole
12-24 month service life stand bye for many year. In fact you can also
find the colors of Blue, Orange, and Yellow. The colors are additives,
meant to distinguish one set of properties from another. Unfortunately
the colors, and additives do not necessarily match from supplier to
supplier. Be sure to read the labels.
adparams.getadspec('c_billboard1');
Firstly, read
your vehicles owner's manual and identify the recommended call out for
the engine coolant. Read the labels carefully to be certain the bottle
in your hand is matched with that recommended in your vehicle manual.
If
in doubt, drain it out! If you can not determine what your current
antifreeze is, drain the entire system, flush it clean, and refill
according to manufactures recommended mix ratio. Never mix
different antifreeze types. The combination of chemicals can cause
unwanted oxidation, corrosion, and degradation of cooling properties.
Keep levels proper. Low levels can allow excess air, coolant cavitation, and yes accelerated corrosion to your cooling system.
Never mix with tap water! Tap water has chemicals that can combine with those in the antifreeze, and cause effects.
Check
your coolant specific gravity with a hydrometer. This simple device
only cost a few dollars at most auto parts stores. It will tell you when
your coolant needs to be changed. Check your level monthly, and the
specific gravity seasonally.
Testimonial: "thank you so much!!!"
