Question about Microsoft Xbox 360 Console
Xbox Live On Westell C90-610030-06 Isn't Working
I have my Ethernet connected to my xbox from my modem/router , and my the modem is plugged into the wall. I've put the DSL cable from my modem into the phone jack on the wall also. WHen I test xbox Live it says Adapter is wired the Ip is connected, the DNS FAILS. I've even manually entered my Primary Dns server, I've port forwarded those numbers, and power cycled, sSAME RESULTS. WHAT DO I DO?
    Problem Solver:
  • 18 Answers
Try to recover yor gamertag. or u can try a different ethernet cable or router or modem. we tried it and after a while it worked just fine.
P.S. My Gamertag is Hickerdinkle
Posted on Jan 11, 2009
    Problem Solver:
  • 11 Answers
If this is the original xbox you have to use a crossover cable especially if your router is the same as your modem (both the same box) (try google for the crossover cable instructions.) if this is the 360 it should just work, also how is your router plugged into your modem or are they the same thing. If that is the case go get a linksys router and set it up so that your modem-router combo plugs into the linksys router which plugs into your xbox (note that this is a fix for the original to.)
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
XBox 360/modem/router set up
go here, www.portforward.com you can find how to setup your xbox here.
May 20, 2009 | Westell Wirespeed LiteLine 6110 Modem
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
How do you get xbox live through a phoneline straght from your computer
If were talking a common router you will have to have a broadband connection going to the box from a local provider and a good signal along with a ethernet cable that you will need to plug into the back of the router and connect to the XBOX 360 ( Note: XBOX ) does not have access to XBOX360 Live . Microsoft offers alot of Tech support on www.xbox.com
Jan 03, 2009 | Westell Wirespeed LiteLine 6100...
Xbox 360 connecting to Xbox Live through Westell 6100 modem
I would greatly suggest to call Xbox live Techsupport. They will help you regarding connectivity issue and its for free!!!
Nov 23, 2008 | Westell Wirespeed LiteLine 6100...
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
