Question about Maytag Atlantis MAV6000 Top Load Washer
Atlantis washer suddenly stopped working at all
Worked fine two days ago, now nothing. seems to have no power, but outlet is working. no water, no noises. seems completely dead. any suggestons?
    New Friend:
  • 88 Answers
I would check your lid swtich first.
Posted on Jan 13, 2009
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Ok, so I have a maytag atlantis serial number MAV7650AWW. Everything worked fine up until a couple days ago, the washer just stopped working it was full of water and seems as if it has no power at all
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jun 25, 2012 | Maytag Atlantis MAV7551 Top Load Washer
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
In the middle wash cycle, the washing machine just suddenly stopped. There is AC output from the wall outlet. I am unable to determine if the problem is electrical, a belt, etc. Help! AtlantisMan
Your posted comments were a big help... The problem was electrical. The lid switch was the problem. I ordered and replaced the switch and it works fine.
Thank you for your help.
Jan 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
