Question about Dyson DC25 All Floors Bagless Upright Vacuum
Vacuum cleaner will not turn on - Dyson DC25 All Floors Bagless Upright Vacuum
  • Official Brand Answer
  • 2,572 Answers
It's Jack at Dyson. I'm sorry to hear you're having difficulty with your DC25. If the machine shut off while you were using it, it may have overheated due to a blockage, or because the filters need a wash. To resolve this, please follow the steps shown in our Online Support guide:
http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/power-failure
If you'd like further assistance after trying this, please give our Helpline a call. For the UK, the number is 0800 298 0298. For the US, the number is 1-866-693-9766
Best wishes,
Jack
Dyson Online Customer Support
Posted on Nov 28, 2012
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
Vacuum cleaner shut off if you try to use the hose or off beater
With the cleaner on. move the cable where it enters the cleaner through a rubber grommet. There is a common fault with these cleaners that the cable breaks at that point. soon the cleaner wont work at all until it is rewired.
Jul 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum just stopped, won't turn on
Take it back under guarantee, could be faulty mains lead or switch or motor
Sep 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Bissell steam cleaner model 9300 not putting out soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Electrolux ambassdor will not run after pluggen in
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 03, 2008 | Electrolux Vacuums
Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Dyson DC25 All Floors Bagless Upright Vacuum Logo
177 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
