Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Mi tv sony gran wega no aparece el color azul por lo tanto se berde y amarillo
Por favor me podrian indicar en que parte se encuentra la funcion flash focus en este modelo de tv KDF-55XS955
SOURCE: necesito ayuda ... en espa?ol
quiero saver como conectar mi camara labtec en mi computador HP
Posted on Jun 30, 2008
SOURCE: problem with my dvd player
Estimado, tenes que correr la llave que esta a la derecha y colocarla en OUT, con eso ya te va a funcionar
Saludos
WP
Posted on Sep 28, 2008
  • 41 Answers
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
  • 76 Answers
SOURCE: al televisor se le ve una mancha azul en el
Call Sony.
Posted on Mar 18, 2010
welcomejee
  • 10594 Answers
SOURCE: lo prendo, enciende normalmente, buena
Is it Sony KP-57WS500 tv or any other model?
Does tv show standby light blinking, if yes, count it after 3 seconds long pause and let me know to diagnose problem.
Posted on Aug 22, 2010
Compr? un Radio Kenwood KDC-X300,cuando programo la hora,la fecha,dem?s funciones,apago mi carro,lo vuelvo a prender,el radio aparece en standby┬┐?lguien de ustedes me podr?a dar una respuesta?
Mi Espa?ol no es my biene ,perdone. Suena Como que lo tiene connectado all ignition solamented. Se nececita conectar el alambre de Acc. A la batteria directamente Para que Guarde la memeoria . Ay beses que se Idica el alabre en question con color azul. Hope it helps Buena suerte,
May 16, 2016 | Cars & Trucks
Para sanyo
Hola, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Sanyo Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar.Si necesita ayuda adicional por favor dejeme saber a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Nov 02, 2013 | DISH Network IR Remote Control
Codigos television panasonic
Para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 685#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar.Si necesita asistencia adicional por favor dejeme saber a: kimberly.escobar@dish.com
Kimberly Escobar
DISH L.L.C
Oct 17, 2013 | DISH Network IR Remote Control
Necesito los codigos del control remoto dish ir remote 103602 para programar television jvc de 27 pulgadas
Juan Francisco! Mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Se que a este punto quizas mi ayuda ya no la necesite. Le proveere los pasos a como programar el control a su Tv por si en un futuro necesita la informacion. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor sientase libre de dejarme saber a kimberly.escobar@dish.com
May 10, 2013 | JVC Televison & Video
Necesito programar un control a tv insignia?
Hola Maria, sera un placer asistirle con la inforamcion que necesita. Disculpe la tardanza en responderle. Quizas en este momento ya no necesite mi ayuda pero de todas manera se la proveere por si en un futuro la necesita. Para que su control funcione con tu TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Sigua este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV (Insignia). Una vez hagas esto te aparecesaran los codigos que posiblemente funcionan con tu TV. El procedimiento a programar su control es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 720#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor o subir el volumen, deberia funcionar. Si funciona asegurese de poner el control en modo de satellite de Nuevo. Esto lo hace oprimiendo el boton de SAT en la parte de arriba de su control una vez solamente. Espero esto le ayude al no ser asi por favor envieme un correo electronico directamente a kimberly.escobar@dish.com
Kimberly Escobar Social Media Representative DISH L.L.C
Jan 16, 2013 | DISH Network IR Remote Control
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
No puedo conectar mi htpc mogul 3800 a wifi de ninguna manera me gustaria el manual o como poder saber si mi equipo cuneta con esta funcion o un tutoril para configurarlo correctamente
Aqui esta el manual, la informacion que nesecita se encuentra en la pagina 127:
http://www.scribd.com/doc/16932430/HTC-Mogul-PPC-6800-User-Guide
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendacion para mi respuesta. Gracias, Jose
Jun 11, 2011 | HTC PPC-6800 Smartphone
NO APARECE MI CAMARA WEB QUE VIENE INCORPORADA A LA LAP, COMO LE HAGO, DICE QUE NO SE ENCUENTRA O QUE ESTA OCUPADA O QUE NO TENGO, QUE DEBO COMPRAR UNA Y ESO NO ES POSIBLE, POR QUE SI TENGO CAMARA WEB,...
que hago tenia instalado en mi pc oficce 2003lo cambie por 2010 pero cuando quiero reproducir una presentacion de power poit dice que no se encuentra el punto de entrada del procedimiento except handler 4 common en la biblioteca de vinculos dinamicoas de msvcrt.dl que devo de hacer por favor quien me puede ayudar
Feb 24, 2011 | Computers & Internet
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
