Question about Dishwashers
No power at. Maybe the fuse blew. Is there a fuse? If so how can I find it . Lg dishwasher model LDF7811ST/01
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
Don't believe there is a fuse. Before you dig into the dishwasher check the outlet that it was connected to. Make sure the wiring didn't come loose from there, or that the cord to the dishwasher isn't damaged.
Posted on Nov 28, 2012
Error meaasage 0E Drain Error what to do?
This OE error or fault code indicates that the machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Mar 01, 2016 | LG 4681EA2001D Original Water Pump Drain...
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
No lights no power in dishwasher
You blew the fuse or bimetal. The fuse will open to prevent the unit from catching on fire. Please flick your breaker and make sure there is nothing else tapped into the same spot as the dishwasher or you will overload it and the fuse will blow again. The unit will most likely need a new control board, p/n #
EBR63265301
Mar 11, 2014 | LG LDF8072ST FulIntegrated Steam...
Parts for LG Dishwasher take weeks to get.
you could order direct... maybe quicker http://www.lg.com/us/support/parts/support-find-parts.jsp I got my part in 3 days
Apr 09, 2010 | LG 24 in. LDF 7811 Stainless Steel...
I have an lg ldf7811st and the bottom arm will not turn. I purchased the part 1267558 (motor assembly, vario spray valve) to repair it and I need instructions on how to install this part. Please advise.
you need to uninstall dishwasher and tip it backwards on the bottom of the dishwasher you will see a square panle remove the 2 screwsand replace the part then proceed in revers to put together
Mar 26, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
