Question about Samsung HP-P5091 50 in. Plasma Television
Need help fixing the volume on my TV?
We recently moved to a new place and we noticed since we moved that the volume is messed up. Usually we watch tv at the 30-40 mark on the volume and now are having to watch it at 60+. Any advice on how I can fix it? Thanks!
    President:
  • 1,284 Answers
You are probably using a cable box that has a lower audio output level. If thats the case have the cable company fix it.
Posted on Jun 08, 2007
Help... got power but no responce from tv
Contact any service technician or the authorized service center for Emerson. Gopakumar Gopalan Google
Feb 25, 2014 | Emerson Televison & Video
We have had a HT-SR800 system in place for a few years. We recently added a Panasonic blu-ray player (may have nothing to do with the problem). Since that time we have needed to continually turn up the...
Consider the audio path that has 'lower' volume. DVR and TV might be one and the same. Does it pass through, say, the TV's volume control, before hitting the reciever on the way to your ears? Use the FIXED audio output if it has one. Or there may be a setting to make it Fixed (constant).
Apr 29, 2011 | Audio Players & Recorders
I have a kenneth cole new york kc3216 just had a battery installed in it at wallmart got home noticed minute hand had moved by itself bumped the watch it moved again what should i do
It's been 2 yrs. I hope you got this solved. If not, it's probably a bad battery or inept install. Some batteries sit on the shelf for a while and aren't rotated. In other cases the installer can innocently and unintentionally bend a battery contact. Rendering the watch useless. Take it back or to a jewelry store. A jewelry store usually has the tools and equipment to fix a messed up contact or at least they'll have a battery tester to determine the battery's charge. Usually a minimal charge like 4-8 bucks.
Apr 01, 2011 | Kenneth Cole New York Automatic Bracelet...
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
Channels keep changing while watching TV !!!
You may have the volume on your invoca set too high and it is picking up speech from the television and misinterpreting it as commands. Check the mic level in your battery compartment and mess with the levels so that it still listens to you, but not the tv :)
You can find the manual here and check pages 53 and 58 for better views :) Let me know if this doesn't help. You may have to move the invoca unit itself to a new location that isn't in the "main blast" of the tv speakers. Best of luck mate! Cheers!
Jun 17, 2010 | KNG America InVoca 3.0 Remote Control
Cracked bulb or lamp?
There are bad solder connections on the Convergence Amp IC's. When you moved it , the connections that were loose are now disconnected. Resolder the pins on these IC's and you should be ready to watch TV again.
Aug 09, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
TV is ON....only ONE STATION. New Remote Batteries. Will Not CHG ch or VOLume
Unplug AC electrical cord for a bit then plug in and see if it resets.......................T.
Feb 12, 2008 | Televison & Video
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Samsung HP-P5091 50 in. Plasma Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
