Question about GE PSS25MGN Side by Side Refrigerator
Ge Refrigerator area heating up
    Top Expert:
  • GE Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Nov 28, 2012
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
The middle of our GE refrigerator is very hot. Why?
There is a loop of tubing from the condensor to warm this area with waste heat (removed during the inside cooling process) This is normal so don't worry about it
Aug 18, 2010 | GE Refrigerators
The top of the refrigerator around the light bulb area is hot which makes all the food near it warm. Is there any way to fix it?
Remove the light bulb for a day.
If the area gets cool with no light bulb you will have to repair/replace the light switch near the door.
If it is still warm you will have tp provide more information to find out what is causing the heat.
Jul 06, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water does not dispence
The water supply tube in the recessed area of the dispenser area has frozen. The only way to thaw it out without turning unit off for 24 hours and leaving the freezer door open is to use a hair dryer to heat the recessed area where the water comes out. The water line supplying water to the door has frozen in that area. It will take you about 1 1/2 hours to 2 hours to do this with door open and using hair dryer. Wish there was another way besides turning unit off for 24 hours but this is a common problem with the GE refrigerators. Soory. Wish I could have been more help. Rick
Mar 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side throws a LOT of heat
It might be low on refrigerant, this is one cause of overheating on the compressor, and condenser. This condition will not affect cooling tho, unless it is really low. As far as making fire, it wont because compressors have a breaker switch that go off when they get too hot.
Jun 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer also just jumped to 17° and won't go down to 0.
We need to check the evaporator fan and the condenser fan. The heat in the door frame is normal when the refrigerator runs normally. But when a control board or fan fails the heat may increase because they are heat strips behind the door or condenser lines placed there to prevent moisture around door seals. We also will need to unplug and have a look at the mother board on back behind a panel. Many times the board will show burn marks on the back or front. When you are ready let me know, Thanks, Sea Breeze
Jun 18, 2009 | GE Profile Arctica 25.4 Cubic Feet...
12 yr old ge refrigerator leaks water on kitchen floor occassiona
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS25MGN Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
