Question about Exercise & Fitness
Nordic Track C1900 when pushing 1mph goes 5mph, calibration POT not lowering
When pushing 1mph the treadmill goes 5mph. I tried the calibration procedure but only moves down to 4.3mph. I there a bad resistor or something easy to change, besides buying a whole controller
    Top Expert:
  • 12,223 Answers
Adjust the speed sensor a) test it b) clean it c) tight the plug or connector very well, see the diagram attached.
2) lube the elevation motor , shaft, and gear. and test it for open or defective motor see the diagram attached.
Again RUN the s. calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Nordic Track C1900 when pushing 1mph goes 5mph, ca - 11_28_2012_3_04_22_pm.gif11_28_2012_3_05_44_pm.jpg
Posted on Nov 28, 2012
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
I have a nordic track c1900 treadmill. It blows the 315mA fuse when I turn on the machine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 09, 2016 | Nordic Track Exercise & Fitness
Nordic track T14.2 treadmill incline issues - not calibrating properly
Hi There, I can't say I know this particular model, but most lift motor assemblies have 3-wires to drive Up and Down windings, and then 3-wires to return a small location signal that gets measured inside the lift gearbox(0-5vdc), and sent as a sample voltage to the upper console to tell it where the lift motor is currently positioned. This pot, or potentiometer, can get dirty, greasy, fail completely, or lose connections inside the gearbox. Do NOT apply 110vac to the pot wires by mistake, as smoke will be the result, oh, and a 13lb boat anchor of a lift assembly ;o) If you have a DMM or a way of checking resistance, you can contact jatinah electronics for further help. Good Luck!
Jan 25, 2015 | Nordic Track Exercise & Fitness
Nordic Track 3000 say I am going 4.9 mph when I push 3mph and when i push 4 it say i am doing 6 what is wrong . a couple days ago it said demo mode, how do I change it from demo mode to regular mode/
RUN the software calibration for easy diagnostic, and fix it. Go to the HOOD cover motor, and follow the steps or ready your owner manual.
God bless you
Sep 29, 2013 | Nordic Track NordicTrack Treadmill, A2550
I HAVE A NORDIC TRACK E 3500 WITH AN INCLINE PROBLEM WHERE BY IT DOSEN'T RESPOND TO THE REQUIRED LEVEL .I'VE TRIED TO RESET MANY TIMES WITH NO SUCCESS .IT SEEMS TO CHANGE THE ACTIONS ON...
1)Lube the shaft, gear from elevation motor see the picture
2) adjust the POT a little.
3) see the diagram attached.
4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it.
God bless you
Nov 11, 2012 | Nordic Track NordicTrack Professional...
Nordic track c1900 how do I remove the hood ?
Dear Sir:
I will help you right now with this Video:
http://www.youtube.com/watch?v=H_ieEByRp34&feature=relmfu
If you need additional Help, please reach me.
Thank you in advance, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
97 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
