Question about Maytag Atlantis MAV6000 Top Load Washer
I have maytag atlantis washer that has stopped working at all. no sounds, no water. seems to have no power, but outlet is good. worked fine two days ago, today it is completely dead. any suggestions?
  • 1 more comment
  • fish458 Mar 10, 2009
    MAYTAG ATLANTIS (MAV8600AWQ) WONT TURN ON...NO WATER NO LIGHTS BUT HAS POWER TO THE TIMER & SPEED SWITCH...THANKS RANDY
  • msmim29 Mar 16, 2009
    I also have a maytag atlantis washer. It stopped working when the lid slipped from my husband,s hand. The washer will not do anything now. It was washing a load when it stopped. The electric outlet is working fine. I have Maytag Atlantis model MAV8600AWW. Can someone help?
  • Anonymous May 19, 2009
    My maytag has just stopped working. I did a load on the weekend and went to do one two days later and it just wont work? Help
  • 4 Answers
Check out the other posts on this forum. Specifically the ones that talk about the lid switch.
Posted on Jan 16, 2009
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Hello, I have a maytag atlantis MAV6000. Everything works fine except when the washer goes to spin cycle. Instead of any of the water draining properly, it all slowly leaks out of the bottom of the...
This is the car and truck section, you may want to repost this in the washer section.
It sounds like the drain hose or pump is stopped up.
Aug 28, 2012 | Cars & Trucks
Ok, so I have a maytag atlantis serial number MAV7650AWW. Everything worked fine up until a couple days ago, the washer just stopped working it was full of water and seems as if it has no power at all
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jun 25, 2012 | Maytag Atlantis MAV7551 Top Load Washer
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer
Your unit has a 10amp inline fuse that is most likely blown it feeds L1 to the timer check that.. if you have the power at the outlet plug in a lamp to make sure Just like Tech17 said..
Jan 15, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Checkign lid switch for maytag washer
unplug the power cable open [panel chech wiring detached /mostly some wiring detach was the line of starter switch / the water valve wiring detached / the machine will pour water if valve are malfanction insert the wire . then ok.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
434 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
