Question about Yamaha Audio Players & Recorders
Yamaha dsp ax 861se service manual for the amp
Would like to buy manual
  • 482 Answers
you can download this service manual free from here.
Thanks.
gylacz
Posted on Nov 29, 2012
  • 236 Answers
SOURCE: Yamaha dsp-A1000 5 ch Amp
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Posted on Aug 04, 2008
  • 85 Answers
SOURCE: where i could find the
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: hi,where can i buy remote controle for yamaha ax
here you can get the original remote.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+ax+396+&uuid=12605921608550
Posted on Dec 12, 2009
tbreeze47
  • 3083 Answers
SOURCE: yamaha dsp-a492 amp keeps switching
Amplifiers have protection circuits that sense current overloads, and especially internal faults, and theyt shut themselves down to prevent further damage to the unit, until it can be troubleshot and fixed. They're designed to allow minimum damage to the unit, and the cause of the overload must be found and fixed by troubleshooting the unit systematically. Sometimes you can get lucky and ohm out a suspected power transistor or IC regulator and replace it successfully, but most of the time a scope is required.
Take it to an audio repair shop and get an estimate first, but know that they do charge by the hour, and it can get a bit expensive.
I noticed this same problem was posted in a couple of forums on the net, but they never got a solution or followed up, so service is in order.
Good luck, and hope this helps.
Posted on Oct 30, 2010
SOURCE: I'm looking for instruction manual for my amp
The manual is available to download on the Yahama site (usa.yamaha.com). Click on the "support" tab.
Posted on Jan 22, 2011
What is the replacement of transistor 2sd 1915?
http://www.datasheetarchive.com/buy/2SD1915.html Costs 87 cents from MCM
Nov 17, 2014 | Yamaha Audio Players & Recorders
The sound of the LEFT MAIN Cannel disappears on my YAMAHA DSP AX-1
The fact that sound appears at max volume means that it is getting past and through the pre-amp stage. So it would appear to be in the main power amp stage the problem. It would depend what drives the channel, but if it's transistor driven I would suspect one of them.
Oct 31, 2012 | Yamaha DSP-AX1 10-Channel Amplifier
I'm looking for instruction manual for my amp Yamaha DSP A-1000 THANK YOU FOR YOUR HELP
Jan 19, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Audio thump on changing any parameter
My bet is a faulty electrolytic capacitor! Don't know which. but would look around the circuit of those stages.
May 30, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
I am looking for the remote control code for the yamaha dsp-ax620? any help please
The code for a Yamaha DSP-AX-620 is 94. Hold down the on/off button on remote while you type in the code. Hope this Helps
Feb 18, 2009 | Yamaha Televison & Video
Problem with my AX 500
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance. Don't matter you could claim 100 times and never loose out. check it out! Also don't 4get to leave me feedback cheers raverbaby01
Aug 27, 2007 | Yamaha DSP-AX1 10-Channel Amplifier
252 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
