Question about Sewing Machines
My sewing machine new home model 535 is breaking top threads all the time i have changed my needle but still breaking can you help
  • Sewing Machines Master
  • 7,365 Answers
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Posted on Nov 28, 2012
  • 185 Answers
SOURCE: industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
Posted on Feb 27, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
SOURCE: Consew 230 continually breaks top thread at needle
What size thread are you using? With thicker fabrics, you should be using at least a size 50. Even a 30 would be better.
Posted on Jan 31, 2011
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
My sewing machine keep sewing a little bit but breaks the thread everytime the bottom thread is at 0 and 1 my top thread is at 2 or 3 and the top thread breaks please tell me what wrong I am new too.
possibly the top thread is being restricted in movement
check that the thread is between the tension plates and not behind it or knotted up in the way it is threaded
pull on the needle thread and it should move with a steady pull not very hard
if it is not moving fairly easily the check how you have the thread installed
also old thread will break easily as the bonding used to keep the strands together breaks down and is difficult for the thread to slide though the needle
another point is the needle to hook timing and the clearance there as well .
if there is a problem there , the hook will split the thread from the needle and break it
if you still have problems , take it to a sewing machine service center ( any one ) and they will advise of the problem and show you how to fix it
Oct 20, 2015 | Sewing Machines
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
New Home 7500 sewing machine top thread keeps breaking?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jan 30, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
New home 535 machine. I've checked the threading, removed any lint or fluff, adjusted the tension and changed the needle. It makes holes but not stitches or gets knotted up and unthreads itself.
check to see if the thread has come off the thread take up lever
check in the needle plate to see if the feed dogs are up or down, if they are down then the knob or switch need to be changed to the up position
if the feed dogs are up then it's possible that they need to be checked
because the feed dogs are what moves the fabric against the presser foot as the machine sews
make sure to have 3 to 6 inch thread tail on top thread & bobbin & pull the thread behind the needle before starting to sew that way the needle does not become unthreaded
and make sure the presser foot in the up position when thread
if none of these suggesions help then it's possible that the machine could be out of time & would have to be serviced by a sewing machine repair tech that has the tools to check the machine
Sep 05, 2011 | New Home Sewing Machines
The top thread keeps breaking. The thread pulls tight and breaks. I have removed a broken thread piece from the upper take-up lever, rethreaded (several times), cleaned out bobbin, moved thread spool on...
try a tension a 3 to 5 on the top tension
try changing to a needle or if it's a new needle make sure the flat side of the needle faces the back of the machine and pushed all the way up into the needle holder
make sure the needle & thread are correct for each other, if the needle is to thin or to heavy for the fabric it will not work
Aug 27, 2011 | Brother InnovIs QC1000 Electronic Sewing...
I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Jul 30, 2010 | Necchi Sewing Machines
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Sewing Machines Logo
113 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
