Question about Microsoft Windows Server Standard 2003 for PC
How can i make exe as a windows service without programming
Hi to all !
My question is, I have an exe which i have to run continuously on the server if i make it as a service i suppose my problem is going to solve.How to make an exe into windows service without writing any program.If i keep an exe some times it will close automatically.dats d problem.So pls help to this.
  • 30 Answers
There are some solutions for your problem, everything has
positive and negative side. (Pro and contra)
1. Startup folder
Put your exe or bat file to the startup folder. The Windows will start automatically when the Windows is starting. You put the exe to the desktop, then copy to Start/Program/Startup folder.
Positive: Quickest setup
Negative: To stop your program, you have to start the taskmanager. (taskmgr) You have to start taskmanager if you want to check the status of your exe.
2. Make a Windows service
Serveral ways can do it. The Windows resource kit contains
two utilities with this programs you can do it.
(instrsrv, srvany)
Here is the appropriate link:
http://www.tacktech.com/display.cfm?ttid=197
You can do it with registry modifications.
Here is the instructons:
http://www.overclock.net/faqs/119474-how-run-program-service.html
Positive: You can control your program from mmc
Negative: A bit complicated
I suggest to use service methotd instrsrv program.
I hope this helps, and you like it. :)
Posted on Jan 10, 2009
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
Tip
How to disable and re-enable hibernation on a computer that is running Windows
The Hiberfil.sys hidden system file is located in the root folder of the drive where the operating system is installed. The Windows Kernel Power Manager reserves this file when you install Microsoft Windows. The size of this file is approximately equal to the amount of random access memory (RAM) that is installed on the computer.
The computer uses the Hiberfil.sys file to store a copy of the system memory on the hard disk when the hybrid sleep setting is turned on. If this file is not present, the computer cannot hibernate.
Hibernation is made unavailable when you set the value of the Hibernate after setting to Never by using the Power Options item in Control Panel. To make hibernation unavailable, follow these steps:
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt, and then click Run as Administrator.
When you are prompted by User Account Control, click Continue.
At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
Type exit, and then press ENTER.
To make hibernation available, follow these steps:
At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Type exit, and then press ENTER to close the Command Prompt window.
APPLIES TO
Windows Vista Business
Windows Vista Enterprise
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Starter
Windows Vista Ultimate
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Web Server 2008
Windows Server 2008 R2 Datacenter
Windows Server 2008 R2 Enterprise
Windows Server 2008 R2 Standard
Windows 7 Enterprise
Windows 7 Enterprise N
Windows 7 Professional
Windows 7 Professional N
Windows 7 Ultimate
Windows 7 Ultimate N
http://support.microsoft.com/kb/920730
on Nov 19, 2013 | Microsoft Windows Vista Home Premium with...
Tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 | Computers & Internet
Getting this error spooler.exe
Spoolsv.exe is a program developed by Microsoft Corp. which is responsible in managing spooled fax or print tasks. Spooling lets the computer user to print in background without having to worry that his or her PC is being tied up. You can found this program at C:\Windows\System32.
Sep 06, 2011 | Microsoft Windows Server Standard 2003 for...
Nokia 6100 contact service solution please
This tutorial will show you how to upgrade your iPhone 4 to iOS 4.3.1 without upgrading its baseband using TinyUmbrella for Windows.
Currently there is an issue with older basebands such as 1.59.00 and FW 4.3.1. Until ultrasn0w is updated, you will only see one bar under signal strength.
Please Note: This ONLY Works with the iPhone 4!
Step One
Download TinyUmbrella from here Also make sure to download the iPhone 4 iOS 4.3.1 which you can find here.
Step Two
Double click the downloaded TinyUmbrella.exe file.
If you get a Windows Firewall notification, check both boxes and click Allow Access.
Step Three
Make sure the device is connected, and Umbrella has detected the type of device and its firmware.
**If you haven't already saved your iOS 4.3.1 SHSH blobs then click Save SHSH. Make sure they successfully save before continuing.
Step Four
Hit Start TSS Server and make sure you receive no errors.
Once The TSS Server is "running" successfully, umbrella will kill iTunes. Leave TinyUmbrella Open. You can double check to see if the TSS server is running under the Log tab.
If you do receive an error, DO NOT continue. Your restore will not work if the TSS server cannot be started.
Step Five
Open iTunes by doubling clicking its icon.
Hold down the Shift key and click Restore
Select your iPhone 4.3.1 firmware file from the popup window that appears and click Open.
Click Restore to begin restoring your device.
Step Six
iTunes should give you error 1013. This is what we wanted, as it notes the baseband has not updated :) Click Ok and close iTunes.
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are working with a device OTHER than iPhone 4.
Step Seven
Place your iPhone into DFU mode by holding down both the Power and Home buttons for ten seconds, then release the Power button and continue holding the Home button for another 5 seconds. You can find help with DFU mode here.
Step Eight
Fix Recovery in TinyUmbrella is currently not working. Download this standalone .exe file to fix recovery on 4.3.1. Extract the file and double click on fixrecovery43.exe. A command prompt will open, and the program will go through the process. During this time, you will notice scrolling text on your iPhone 4.
Step Nine
Your iPhone will now be on 4.3.1 with the 1.59.00 baseband! (Which means you can now unlock using this tutorial)
**Thanks to semaphore for his work on this tool
Nov 18, 2009 | Nokia 6100
I would like to know why I continually lose connection while playing YoVille game on Facebook? I'm usually in the middle of a game, and it says I need to refresh, which causes me to loose coins. I asked...
The free file information forum can help you find out if csrcs.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
csrcs.exe file information
The process belongs to the software CSRCS.EXE by unknown.
Description: File csrcs.exe is located in the folder C:WindowsSystem32.
Program has no file description. The program is not visible. The file is located in the Windows folder, but it is not a Windows core file. HKEY_CURRENT_USERSOFTWAREMicrosoftWindowsCurrentVersionRunOnce, HKEY_USERS.DEFAULTSoftwareMicrosoftWindowsCurrentVersionRunonce).
It is not a Windows system file. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to hide itself, monitor applications. Therefore the technical security rating is 100% dangerous.
Important: Some malware camouflage themselves as csrcs.exe, particularly if they are located in c:windows or c:windowssystem32 folder. Thus check the csrcs.exe process on your pc whether it is pest. We recommend Security Task Manager:
http://www.neuber.com/taskmanager/index.html?ref=file.net
for verifying your computer's security.
If this information is useful, please mark as helpful. Thanks
Oct 03, 2009 | Microsoft Windows XP Home Edition
Everytime i open my computer, ah pop-up windows say's WINDOWS CANNOT FIND SCVHOST.EXE
First, I'll let you know what's going on, then I'm going to post from Microsoft, what svchost.exe does, and how to find out where the problem is. I can help you further if you need it.
Svchost.exe is a program in WIndows XP Pro that will start services in your computer during startup. It sounds like you have deleted a program and "service host" is still looking for it to open on startup. This can happen if the program was removed without using the correct removal procedures. It is still listed in the registry and your computer is still trying to access it. DO NOT edit your registry unless you know what you are doing. You could create a catastrophic failure of Windows. There are programs that will remove registry entries if those entries are no longer valod. You can fing a free program for this function at web sites like www.nonags.com
Following is information from the Microsoft web site:
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the following registry key, whose Parameters key contains a ServiceDLL value: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Service To view the list of services that are running in Svchost:
  1. Click Start on the Windows taskbar, and then click Run.
  2. In the Open box, type CMD, and then press ENTER.
  3. Type Tasklist /SVC, and then press ENTER.
Tasklist displays a list of active processes. The /SVC switch shows the list of active services in each process. For more information about a process, type the following command, and then press ENTER: Tasklist /FI "PID eq processID" (with the quotation marks) The following example of Tasklist output shows two instances of Svchost.exe that are running. Image Name PID Services
System Process 0 N/A
System 8 N/A
Smss.exe 132 N/A
Csrss.exe 160 N/A
Winlogon.exe 180 N/A
Services.exe 208 AppMgmt,Browser,Dhcp,Dmserver,Dnscache,
Eventlog,LanmanServer,LanmanWorkstation,
LmHosts,Messenger,PlugPlay,ProtectedStorage,
Seclogon,TrkWks,W32Time,Wmi
Lsass.exe 220 Netlogon,PolicyAgent,SamSs
Svchost.exe 404 RpcSs
Spoolsv.exe 452 Spooler
Cisvc.exe 544 Cisvc
Svchost.exe 556 EventSystem,Netman,NtmsSvc,RasMan,
SENS,TapiSrv
Regsvc.exe 580 RemoteRegistry
Mstask.exe 596 Schedule
Snmp.exe 660 SNMP
Winmgmt.exe 728 WinMgmt
Explorer.exe 812 N/A
Cmd.exe 1300 N/A
Tasklist.exe 1144 N/A
The registry setting for the two groupings for this example are as follows: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Svchost:
Netsvcs: Reg_Multi_SZ: EventSystem Ias Iprip Irmon Netman Nwsapagent Rasauto Rasman Remoteaccess SENS Sharedaccess Tapisrv Ntmssvc
RApcss :Reg_Multi_SZ: RpcSs
Jun 18, 2009 | Microsoft Windows XP Professional for PC
My antivirus wont run and i cant install any other antivirus
Have you tried to start the system in safe mode? F6 I think, then start in safe mode with network. then try to start your norton AV again and try to do a liveupdate, then scan your system and see if it works.. otherwise just uninstall norton, then reinstall it and run live update again and scan your system. My thought is that you have a serious virus on your sysstem.. best thing I can say is WHEN you get your antivirus to work again make a habit of scanning every file you download and from whatever site you dl from.. do NOT believe it when a window pops up and says you need to update your antivirus software.. ONLY use the liveupdate. Another POSSIBLE fix is to use the RESTORE option and try to restore to a point BEFORE you started noticing problems with your antivirus
May 23, 2009 | Microsoft Windows XP Professional With...
Hijack taskmanag and hijack regedit removing
to repair it you need to install autorun eater.
download here: http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
install and it will scan.
also suggested to install avira, bitdefender or mcafee(trial also work).
after install.
restart: press f8 you will enter safe mood. in the safe mood you will see a icon on your taskbar name by mcdonald(the autorun eater software. right click and selct repair task manager, right click again selecr repair regedit and do the same thing select repair folder option.
after that wait untill about 30 minutes(autorun eater to finish scan)
to repair other like no desktop icon download the repair utilities here:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Jan 27, 2009 | Dell Latitude D600 Notebook
UST Scandal.avi.exe
1. Start Notepad
2. Copy the following text. (note: Everything in between the square brackets should be in one line)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\IniFileMapping\Autorun.inf]
@="@SYS:DoesNotExist"
3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part)
4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear.
But what if you are already infected with the virus? There are several programs on the internet that you can download. Here are some of those programs that can be helpful:
Taga Lipa Are Remover (or Noob Killer) by Leerz (<--click to download)
else
first download taskiller in http://www.rsdsoft.com/task_killer/index... and install it to
your computer because you cant use taskmanager to terminate the virus(the virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
-thats all
(* from support forume)
Nov 22, 2007 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
3,497 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
