Question about Home Security
I purchased a home with a First Alert Professional FA260 alarm system. We don't know the code to operate it. Is there a way to reset the original code?
Cannot operate. Need to reset original code
ford_67
  • 34 Answers
SOURCE: first alert fa260 security system
Sounds like a low battery.
Posted on Aug 24, 2008
  • 273 Answers
SOURCE: I need an instruction manual for a DSC PC500RK home alarm system
try elitezoom.com or safemanuals.com they may have 1
Posted on Aug 26, 2009
szanti
  • 36 Answers
SOURCE: require a manual for a home security/alarm system
go to this web site ITI is now GE
http://www.gesecurity.com/portal/site/GESecurity/menuitem.45121a7b14f68165b1e2ff10140041ca/?vgnextoid=343a148067b33010VgnVCM100000410014acRCRD
Posted on Nov 29, 2009
  • 14 Answers
SOURCE: I moved into a home with a Honeywell system, but
if you take the front face off there should be a pin hole around the keypad area and if you take a paper clip and push this it will do a master reset. the only thing about this is you will have to reprogram the whole system. you might be able to scroll thru the option and if you see a setting called master code enter the default code wich is probably 123456 if this works then you can add and delete codes. once you do this you may want to change your administrator code.
Posted on Mar 14, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a First Alert FA260 alarm system and I do
In the bottom of the cabinet, you’ll see the backup battery, connected to the main board by a red and a black wire. Normally these wires have connectors that plug onto the battery posts. Take a look at those connections, which should be tight and clean. If you see an accumulation of chalky gray powder around the terminals, you may have to replace the connectors as well. That’ll depend on whether the old connector #after cleaning with an old toothbrush# is in good enough condition to re-use.
The next step is to find the battery specifications. Look at the hookup diagram on the inside of the cover. You’ll usually find the specifications there. If the diagram is missing or does not have the specs, you can get them off the old battery itself. Here’s what you’ll need.
There are three parts to the specification: voltage, capacity, and battery type.
The voltage is the easiest, and most alarm panels use 12 volt batteries.
The capacity will be listed in either ampere hours #abbreviated aH# or milliampere hours #abbreviated maH#.
The battery type refers to the chemical composition of the battery. It’s important to select the correct type because the charging circuit is designed for that type. The common types are Nickle Cadmium #NICAD#, Sealed Lead Acid #SLA#, and Gel Cell #GC).
With this information in hand, you can shop the Internet for a replacement. Perform a Google search for “alarm battery” or “DIY alarms.” You’ll get several vendors, each with a means to drill down to batteries. You’ll find several different brands as well. You don’t have to get the same brand that you had, but the specifications need to match. Voltage and type must be an exact match. The capacity can vary a bit. For example, if you have a 4 aH battery, a 4.5 aH battery will be fine. Just keep in mind that the higher the capacity, the larger the battery’s dimensions will be. While there’s usually plenty of space in the cabinet, getting an 8 aH battery to replace one that’s 4 aH will probable not fit in the cabinet.
Once you get the battery, replacement is as easy as unplugging the old one, and plugging in the new one. It will begin to charge immediately, and any trouble condition should clear within a few minutes.
Posted on Aug 03, 2010
How much a home alarm system cost?
the actual cost of an alarm system varies by company. most companies want the monthly monitoring revenue and offer the installation and equipment as an incentive for signing up with the service. to purchase equipment directly can vary greatly by type of equipment, number of devices and services wanted. your best option is to get at least three quotes from and compare what you are getting for you dollar. most alarm contracts for monitoring auto-renew after the initial term so you want to watch for that. most often batteries and acts of nature are not covered under any warranty.
Oct 15, 2014 | Home Security
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
What does check 11 means on my First Alert FA260 alarm system.
what does check 10 motion mean on my First Alert FA260
Mar 20, 2013 | First Alert Fa260 Keypad
Change nsin alarm code
Any one got a instruction book for one of these alarms carnt find mine and carnt remember how to re program it
Nov 18, 2012 | House Brand 2x Intrud Alert House Alert...
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
What is the code of ms power point
The code should be on the back of the MS office CD that you purchased, however sometimes windows 7 comes with a free 30 day trial, if your not willing to pay for MS office why don't you try open office, it's free and basically the same as MS office.
Jul 21, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
Aug 27, 2010 | House Brand Intrud Alert House Home Alarm...
Home Security Logo
218 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
