Question about Panasonic Televison & Video
My Panasonic 26" LCD TV TX26LXD60 is frozen on return after trying to do a factory reset
The TV would not change channels so I tried a factory reset but is now frozen on re-tune. It is connected to an outdoor aerial which works fine with all other tvs in the house. Any ideas
    Top Expert:
  • Panasonic Master
  • 74,496 Answers
Sounds that the firmware have been corrupted. You might have to upgrade the firmware. If you are confident, you can do it by yourself. If not, seek help of any experienced service technician.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 28, 2012
Arpi
  • 326 Answers
SOURCE: philips 26pf5320
Hello, one of possible solutions is to replace T7735 by the same type of transistor and L5753 (220uH use 470uH). This is a job for a technician. Best regards, Arpi
Posted on Apr 26, 2007
  • 579 Answers
SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Posted on Dec 06, 2009
  • 5190 Answers
SOURCE: My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
Posted on May 01, 2010
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
Toshiba 26AV500U This is being used as a 2nd set connected to a DishNetwork receiver. The set must be tuned to channel 73 to receive the signal, and no matter what I try the TV will not recognize 73 as a...
Tries tv unplug,replug it back like about an hour later.For forcing the tv do a resetting itself back to the factory setting.The tv now should be recognizing channel 73.
Feb 26, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
I deleted all the channels off my tv and can't get them back
you could try reset the tv to factory settings other than that i would sugest a new antena or getting a specialist to fix it.
Jan 31, 2011 | Syntax Olevia 226T 26 in. LCD Television
My 26LG300 works for about a minute and then screen goes blank and says no signal. I change channel...same thing happens?
Tries unplug,replug the tv and cable box back like an hour later.The tv now,should reset itself back to the factory setting.The cable box will,reseting itself and updated it softwares.The tv should work now.
Oct 21, 2010 | LG 26LG30 26 in. LCD TV
May 01, 2010 | Sharp Televison & Video
Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jun 04, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Cannot change channels in digital mode
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
